3 Replies Latest reply on Sep 20, 2014 11:51 AM by ssprengel
    Big problem with D810 images
    muxel Level 1
      I have a big problem with lightroom. It displays artefacts in pictures in which there should not be any. An example is the following:
      The same picture converted with Nikon ViewNX 2, exportet to 16bit TIF and reimported into Lightroom is much better:
      Is there anything I can do? Is there some problem with my settings? Is this a known problem on the lightroom side? Will there be fixes improvements? Can this be due to active d-lightning without lightroom knowing about it?
      Thanks for any help and suggestions!
        • 1. Re: Big problem with D810 images
          Jao vdL Adobe Community Professional & MVP
          There is a posterization issue with the camera matching profiles that Lightroom has for the D810. This could well be it. AFAIK there is no update for those yet. Try a different camera profile such as Adobe Standard. If that fixes the posterization than it is this issue and you'll have to wait until the next Lightroom update to get updated profiles (hopefully).
          No, but it is advisable to not use any modes like this in camera when you use Lightroom or any other non-Nikon raw software because all that the camera does to the raw is to underexpose it and save an instruction to apply a HDR treatment in Nikon's raw software. Other software won't be able to read that instruction and it will make the images appear underexposed as they actually are.
          • 2. Re: Big problem with D810 images
            muxel Level 1
            OK, thanks! Switching to portrait solves the problem. Thanks again!
            • 3. Re: Big problem with D810 images
              ssprengel Adobe Community Professional & MVP
              Adobe has a Help page where you can download beta profiles that fix the issue.  Of course the profiles would need to be updated to the non-beta versions when the next version of ACR and LR come out so I would use them sparingly and add a keyword or something to each image you use them on so you can identify them, later, to switch the profiles to the production version.
              http://helpx.adobe.com/lightroom/kb/camera-standard-profile-displays-posterized.html
