This content has been marked as final.
Show 3 replies
1. Re: Set keyboard shortcut for "Commands > Apply Source Formatting" command in DW CS 5.5
Nancy O. Sep 21, 2014 11:27 AM (in response to Software PR)Most Ctrl+ letter combinations are already in use for other functions like D=duplicate, C=copy, X=cut, etc... So try using a different key combination like Ctrl+Q. I just tested that combination in CS6 and it worked just fine.
Nancy O.
2. Re: Set keyboard shortcut for "Commands > Apply Source Formatting" command in DW CS 5.5
Software PR Sep 21, 2014 11:31 AM (in response to Nancy O.)Thank you for the reply Nancy. I was hoping I could use the Ctrl+D. Is there no way to use that combination and un-assign it from Duplicate command? If not I will accept your answer.
3. Re: Set keyboard shortcut for "Commands > Apply Source Formatting" command in DW CS 5.5
Nancy O. Sep 21, 2014 11:42 AM (in response to Software PR)I don't know of any way to un-assign what's already reserved by your operating system & software. However you could try another key combination like Ctrl+Alt+D.
Nancy O.
