5 Replies Latest reply on Oct 11, 2018 5:01 AM by Natesroom1
    Illustrator script to create symbols from images in folder
    osc Level 1
      Time to give back to the community...
      Here is a script I recently devised to bulk create symbols from images in a folder. Tested with Illustrator CC 2014.
      // Import Folder's Files as Symbols - Illustrator CC script
      // Description: Creates symbols from images in the designated folder into current document
      // Author     : Oscar Rines (oscarrines (at) gmail.com)
      // Version    : 1.0.0 on 2014-09-21
      // Reused code from "Import Folder's Files as Layers - Illustrator CS3 script"
      // by Nathaniel V. KELSO (nathaniel@kelsocartography.com)
      #target illustrator
      function getFolder() {
        return Folder.selectDialog('Please select the folder to be imported:', Folder('~'));
      function symbolExists(seekInDoc, seekSymbol) {
          for (var j=0; j < seekInDoc.symbols.length; j++) {
              if (seekInDoc.symbols[j].name == seekSymbol) {
                  return true;
          return false;
      function importFolderContents(selectedFolder) {
          var activeDoc = app.activeDocument;     //Active object reference
        // if a folder was selected continue with action, otherwise quit
        if (selectedFolder) {
              var newsymbol;              //Symbol object reference
              var placedart;              //PlacedItem object reference
              var fname;                  //File name
              var sname;                  //Symbol name
              var symbolcount = 0;        //Number of symbols added
              var templayer = activeDoc.layers.add(); //Create a new temporary layer
              templayer.name = "Temporary layer"
              var imageList = selectedFolder.getFiles(); //retrieve files in the folder
              // Create a palette-type window (a modeless or floating dialog),
              var win = new Window("palette", "SnpCreateProgressBar", {x:100, y:100, width:750, height:310});
              win.pnl = win.add("panel", [10, 10, 740, 255], "Progress"); //add a panel to contain the components
              win.pnl.currentTaskLabel = win.pnl.add("statictext", [10, 18, 620, 33], "Examining: -"); //label indicating current file being examined
              win.pnl.progBarLabel = win.pnl.add("statictext", [620, 18, 720, 33], "0/0"); //progress bar label
              win.pnl.progBarLabel.justify = 'right';
              win.pnl.progBar = win.pnl.add("progressbar", [10, 35, 720, 60], 0, imageList.length-1); //progress bar
              win.pnl.symbolCount = win.pnl.add("statictext", [10, 70, 710, 85], "Symbols added: 0"); //label indicating number of symbols created
              win.pnl.symbolLabel = win.pnl.add("statictext", [10, 85, 710, 100], "Last added symbol: -"); //label indicating name of the symbol created
              win.pnl.errorListLabel = win.pnl.add("statictext", [10, 110, 720, 125], "Error log:"); //progress bar label
              win.pnl.errorList = win.pnl.add ("edittext", [10, 125, 720, 225], "", {multiline: true, scrolling: true}); //errorlist
              //win.pnl.errorList.graphics.font = ScriptUI.newFont ("Arial", "REGULAR", 7);
              //win.pnl.errorList.graphics.foregroundColor = win.pnl.errorList.graphics.newPen(ScriptUIGraphics.PenType.SOLID_COLOR, [1, 0, 0, 1], 1);
              win.doneButton = win.add("button", [640, 265, 740, 295], "OK"); //button to dispose the panel
              win.doneButton.onClick = function () //define behavior for the "Done" button
                  win.close();
              win.center();
              win.show();
              //Iterate images
              for (var i = 0; i < imageList.length; i++) {
                  win.pnl.currentTaskLabel.text = 'Examining: ' + imageList[i].name; //update current file indicator
                  win.pnl.progBarLabel.text = i+1 + '/' + imageList.length; //update file count
                  win.pnl.progBar.value = i+1; //update progress bar
                  if (imageList[i] instanceof File) {
                      fname = imageList[i].name.toLowerCase(); //convert file name to lowercase to check for supported formats
                      if( (fname.indexOf('.eps') == -1) &&
                          (fname.indexOf('.png') == -1)) {
                          win.pnl.errorList.text += 'Skipping ' + imageList[i].name + '. Not a supported type.\r'; //log error
                          continue; // skip unsupported formats
                      else {
                          sname = imageList[i].name.substring(0, imageList[i].name.lastIndexOf(".") ); //discard file extension
                          // Check for duplicate symbol name;
                          if (symbolExists(activeDoc, sname)) {
                              win.pnl.errorList.text += 'Skipping ' + imageList[i].name + '. Duplicate symbol for name: ' + sname + '\r'; //log error
                          else {
                              placedart = activeDoc.placedItems.add(); //get a reference to a new placedItem object
                              placedart.file = imageList[i]; //link the object to the image on disk
                              placedart.name =  sname; //give the placed item a name
                              placedart.embed();   //make this a RasterItem
                              placedart = activeDoc.rasterItems.getByName(sname); //get a reference to the newly created raster item
                              newsymbol = activeDoc.symbols.add(placedart); //add the raster item to the symbols
                              newsymbol.name = sname; //name the symbol
                              symbolcount++; //update the count of symbols created
                              placedart.remove(); //remove the raster item from the canvas
                              win.pnl.symbolCount.text = 'Symbols added: ' + symbolcount; //update created number of symbols indicator
                              win.pnl.symbolLabel.text = 'Last added symbol: ' + sname; //update created symbol indicator
                  else {
                      win.pnl.errorList.text += 'Skipping ' + imageList[i].name + '. Not a regular file.\r'; //log error
                  win.update(); //required so pop-up window content updates are shown
              win.pnl.currentTaskLabel.text = ''; //clear current file indicator
              // Final verdict
              if (symbolcount >0) {
                  win.pnl.symbolLabel.text = 'Symbol library changed. Do not forget to save your work';
              else {
                  win.pnl.symbolLabel.text = 'No new symbols added to the library';
              win.update(); //update window contents
              templayer.remove(); //remove the temporary layer
          else {
              alert("Action cancelled by user");
      if ( app.documents.length > 0 ) {
          importFolderContents( getFolder() );
      else{
          Window.alert("You must open at least one document.");
