0 Replies Latest reply on Sep 21, 2014 7:26 PM by zBernie
    Synchronizing some folders in LR 5.6 hangs
    zBernie Level 1
      When I synchronize certain folders in LR 5.6, the process hangs, and I have to cancel the import and exit LR.  The folder in question only has 366 photos and videos.  This is occurring on my Macbook running Mavericks 10.9.4.  So, I monitored the log file during the import, and got the errors below.  The critical part of the error is:
         Bad sqlite return code: 19. Info: columns lc_idx_filename, folder are not unique
      I believe the error is caused by LR trying to import photos and or videos that already exist in the catalog.  I can see that some of the photos already exist in the catalog when I check the "Show import dialog before import".   Knowing the error is caused by non unique file names, I deleted all 366 photos from the catalog (But left them on disk, then the folder sync worked.  This workaround works, but can anyone tell me if there is a way to rebuild the LR indexes, or correct the problem via some other means?
      Marker - Sep 21, 2014, 10:09:09 PM
      Sep 21 22:09:31 --- last message repeated 1 time ---
      Sep 21 22:09:32 macbook.home Adobe Photoshop Lightroom 5[1387]:
              0: method   runToCompletion                - C
              1: method   exec                           - 59600407:493+29
              2: method   exec                           - 1098400342:832+5
              3: method   new                            - 1100780495:39+13
              4: upvalue  ?                              - 219380148:280+8
              5: upvalue  ?                              - 219380148:451+16
              6: method   save                           - 219380148:1349+7
              7: method   sqlQuery                       - 219380148:735+12
              8: upvalue  ?                              - 1626841921:187+40
              9:          [unnamed]                      - 1626841921:306+56
             10:          [unnamed]                      - tail
             11: method   createMetadata                 - 1216069304:338+41
             12: field    initializeMetadataForImage     - 1597059609:283+20
             13: upvalue  ?                              - 209166131:556+44
             14:          [unnamed]                      - 209166131:980+43
             15:          [unnamed]                      - tail
             16:          [unnamed]                      - 219380148:965+5
             17: global   pcall                          - C
             18:          [unnamed]                      - 219380148:843+53
             19:          [unnamed]                      - tail
             20: global   pcall                          - C
             21:          [unnamed]                      - 1098400342:526+44
             22:          [unnamed]                      - tail
             23: upvalue  ?                              - 209166131:173+7
             24:          [unnamed]                      - 209166131:950+26
             25: global   pcall                          - C
             26:          [unnamed]                      - 1002929302:1193+34
             27:          [unnamed]                      - tail
             28:          [unnamed]                      - tail
             29:          [unnamed]                      - tail
             30: method   dispatch                       - 1002929302:971+75
             31:          [unnamed]                      - 1002929302:1679+77
             32: global   AgCallWithAutoreleasePool      - C
             33: method   run                            - 1002929302:1642+28
             34:          [unnamed]                      - 435542093:0+6
              0: method   reset                          - C
              1: method   reviveReusableCachedStatement  - 944881066:368+10
              2: method   prepareRunToCompletionStatement - 59600407:1041+4
              3: method   exec                           - 59600407:493+23
              4: method   exec                           - 1098400342:832+5
              5: method   new                            - 1100780495:39+13
              6: upvalue  ?                              - 219380148:280+8
              7: upvalue  ?                              - 219380148:451+16
              8: method   save                           - 219380148:1349+7
              9: method   sqlQuery                       - 219380148:735+12
             10: upvalue  ?                              - 1626841921:187+40
             11:          [unnamed]                      - 1626841921:306+56
             12:          [unnamed]                      - tail
             13: method   createMetadata                 - 1216069304:338+41
             14: field    initializeMetadataForImage     - 1597059609:283+20
             15: upvalue  ?                              - 209166131:556+44
             16:          [unnamed]                      - 209166131:980+43
             17:          [unnamed]                      - tail
             18:          [unnamed]                      - 219380148:965+5
             19: global   pcall                          - C
             20:          [unnamed]                      - 219380148:843+53
             21:          [unnamed]                      - tail
             22: global   pcall                          - C
             23:          [unnamed]                      - 1098400342:526+44
             24:          [unnamed]                      - tail
             25: upvalue  ?                              - 209166131:173+7
             26:          [unnamed]                      - 209166131:950+26
             27: global   pcall                          - C
             28:          [unnamed]                      - 1002929302:1193+34
             30:          [unnamed]                      - tail
             31:          [unnamed]                      - tail
             32: method   dispatch                       - 1002929302:971+75
             33:          [unnamed]                      - 1002929302:1679+77
             34: global   AgCallWithAutoreleasePool      - C
             35: method   run                            - 1002929302:1642+28
             36:          [unnamed]                      - 435542093:0+6
      Sep 21 22:09:32 macbook.home Adobe Photoshop Lightroom 5[1387]: assertion failed!
