This content has been marked as final.
Show 1 reply
1. Re: Can we make quadtone photographs in 16 or 32 bit?
c.pfaffenbichler Sep 21, 2014 11:27 PM (in response to cteavin)As, to the best of my knowledge, pretty much all commercial print devices work with 8bit the point may be somewhat academical.
But especially if the Curves you use are extreme and the original image is available in 16bit or as RAW data you may indeed get better results from applying the Curves in 16bit.
You can do this if instead of using Duotone you create Spot Channels manually.
