1 Reply Latest reply on Aug 16, 2007 12:52 PM by batmitra
    Flex 2 + Yahoo API problemmo....
    Clark_Kent101
      Hi there,
      I've put together an application which incorporates the Yahoo! Maps API. More info regarding that can be found here - the problem I am experiencing at the moment is with markers I've added to the yahoo map not functioning properly when incorporated into Flex 2. After adding a marker to the map from within the Flash 8 environment and then running it (ctrl + enter), everything works like it should - the marker displays correctly and when clicked, provided it has a description, the marker expands to display the description.
      After publishing the API from Flash 8 and loading it into Flex, the map works like it should but the markers do not expand to display the description after clicking on one. I find I have to keep clicking on the marker i want to expand loads of times to get it to expand at least once (if i'm lucky). Is there a workaround or some fix for this? A working example of what I'm trying to achieve can be viewed here. Launch the site and click on any marker displayed on the map - it expands properly containing links - question is, was that application developed in Flex?
      Any help on this would be grand.
      Thanks for your time,
      - Tony
