1. Re: Creative cloud sync problem
wolfgangihloff Sep 22, 2014 2:39 AM (in response to Evgeniy.K)Can you sync any files? Are you using the Web UI or the Client? Which operating system are you on or which browser and version are you using? Which version of the client are you using?
3. Re: Creative cloud sync problem
wolfgangihloff Sep 22, 2014 4:15 AM (in response to Evgeniy.K)What is the path to the folder, those files are in? Maybe the folder cannot be created in the first place? Is this in a collaboration?
5. Re: Creative cloud sync problem
wolfgangihloff Sep 22, 2014 6:03 AM (in response to Evgeniy.K)It seems the uploads for bigger files is failing for you. I tried on my client and it worked. Can you check your log or share your log, it is in
Windows: ~/AppData/Roaming/Adobe/CoreSync
6. Re: Creative cloud sync problem
Evgeniy.K Sep 22, 2014 7:23 AM (in response to wolfgangihloff)that is the part of the todays log
20140922-163029.633: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateOffline (5)
20140922-163029.636: BaseControllerDelegate::pushSyncProgress {67 of 69 }
20140922-163051.979: CbJobProgress::SyncProgress: 68/69, s=847082 t=184 total=2849405523 cur=2692875423
20140922-163051.980: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163051.983: BaseControllerDelegate::pushSyncProgress {68 of 69 }
20140922-163053.639: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163053.639: AcslSvcFS::ParseError: err=3 code=32, reqid=, resp=
20140922-163053.651: Copy New 'C:\Users\Evgeniy\Creative Cloud Files\Projects\Simbla\UI\simblaUI2.psd' -> 'acsl://scss.adobesc.com:80/files/Projects/Simbla/UI/simblaUI2.psd'
- ERROR: Copying file: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163053.651: Finish UL: /Projects/Simbla/UI/simblaUI2.psd (New): Copying file: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163053.651: CbJobProgress::SyncProgress: 68/69, s=846549 t=184 total=2849405523 cur=2692875423
20140922-163053.652: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163053.653: Force connectivity check on item error
20140922-163053.654: Network disconnect detected, change to offline
20140922-163053.654: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163053.655: BaseControllerDelegate::pushSyncProgress {68 of 69 }
20140922-163053.658: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateOffline (5)
20140922-163102.191: CbJobProgress::SyncProgress: 69/69, s=851638 t=155 total=2849405523 cur=2716727843
20140922-163102.192: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163102.195: BaseControllerDelegate::pushSyncProgress {69 of 69 }
20140922-163105.009: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163105.289: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163114.978: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163114.978: AcslSvcFS::ParseError: err=3 code=32, reqid=, resp=
20140922-163114.983: Copy New 'C:\Users\Evgeniy\Creative Cloud Files\Projects\sodaclean\sodaclean.psd' -> 'acsl://scss.adobesc.com:80/files/Projects/sodaclean/sodaclean.psd'
20140922-163114.983: Finish UL: /Projects/sodaclean/sodaclean.psd (New): Copying file: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140922-163114.983: CbJobProgress::SyncProgress: 69/69, s=848447 t=156 total=2849405523 cur=2716727843
20140922-163114.984: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163114.984: Force connectivity check on item error
20140922-163114.984: Network disconnect detected, change to offline
20140922-163114.987: BaseControllerDelegate::pushSyncProgress {69 of 69 }
20140922-163114.993: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateOffline (5)
20140922-163115.002: Sync finished with 69 errors. Click Errors button to see sync errors
20140922-163115.003: Items Synced OK: , Errors: 69
20140922-163115.003: ===== 22/09/2014 16:31:15: Sync Completed. Time: 00:53:23, Speed: 828 KB/s (2.66 MB/s) =====
20140922-163115.022: BaseControllerDelegate::pushQuota {storageFree:107016441689, storageTotal:107374182400}
20140922-163115.025: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163115.027: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncError (3)
20140922-163115.030: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140922-163115.030: WControllerDelegate::syncStatus state 3 (CoreSyncStateSyncError)
20140922-163115.038: BaseControllerDelegate::pushSyncStatus: sent CoreSyncStateSyncError (3)
20140922-163115.038: BaseControllerDelegate::pushSyncErrorStatus: received 69 errors with label 'Unable to sync 69 files'. shouldSuppressErrorNotification: FALSE
20140922-163551.965: Informational: [livetype] onTextReceived livetype.PreferencesRequest
20140922-163551.965: Informational: [livetype] sendText apps.livetype.PreferencesResponse (ON,signedIn=TRUE)
20140922-163602.556: Informational: [livetype] onTextReceived cosy.fonts.FontsInfoRequest
20140922-163602.556: Informational: [livetype] sendText accc.fonts.FontsInfoResponse (7 items - C:6,A:1)
20140922-164409.992: Informational: [livetype] onResponseHeaders
20140922-164409.993: Warning: [GUDE]: Request Failed. ErrorCode: 504 errorMessage: HTTP Status 5xx (Server Error). 504 Gateway Timeout. Initial Request Failed (No Retry Attempted)
20140922-164409.993: Informational: [livetype] longpoll: request timed out at gateway (504). will retry
20140922-164409.993: Informational: [livetype] longpoll: Sending long poll request to https://polka.typekit.com/subscribe?adobe_id=4069332E5309C5EB0A490D45%40AdobeID&entitlemen t_state=6b015fe1d523568761e29b8b748639dacce11756
20140922-164409.993: Informational: [livetype] downloadToFile (id=longpoll) => 5485
20140922-164409.996: Informational: [livetype] onAddParameters
20140922-164409.996: Informational: [livetype] onSetTimeout
20140922-164409.996: Informational: [livetype] longpoll: setting poll timeout to 3600
20140922-164410.004: Informational: [livetype] onAddHeaders (id=longpoll)
7. Re: Creative cloud sync problem
wolfgangihloff Sep 22, 2014 9:05 AM (in response to Evgeniy.K)I do not see any indication in the log that the files you have in the screenshot failed. Also it seems your client had some network connectivity issues. Can you search for the log for files that are reported in the Creative Cloud client as failing to sync, if you find helpful details there?
8. Re: Creative cloud sync problem
Evgeniy.K Sep 22, 2014 11:07 PM (in response to wolfgangihloff)maybe here !?
20140923-085429.535: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085429.538: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085429.772: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085430.310: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085430.554: Warning: [GUDE]: Chunk 8 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085430.939: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085430.997: Warning: [GUDE]: Chunk 5 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085431.167: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085431.600: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085432.202: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085432.820: Warning: [GUDE]: Chunk 7 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085432.867: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085433.888: CbJobProgress::SyncProgress: 1/69, s=496693 t=5717 total=2849405523 cur=9437184
20140923-085433.888: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085433.891: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085434.026: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085434.482: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085435.121: CbJobProgress::SyncProgress: 1/69, s=599186 t=4734 total=2849405523 cur=12582912
20140923-085435.122: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085435.124: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085435.604: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085436.806: CbJobProgress::SyncProgress: 1/69, s=619613 t=4576 total=2849405523 cur=13631488
20140923-085436.806: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085436.808: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085437.591: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085440.351: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085441.055: CbJobProgress::SyncProgress: 1/69, s=543706 t=5213 total=2849405523 cur=14680064
20140923-085441.055: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085441.058: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085441.842: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085442.238: CbJobProgress::SyncProgress: 1/69, s=561737 t=5044 total=2849405523 cur=15728640
20140923-085442.238: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085442.240: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085442.942: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085443.241: CbJobProgress::SyncProgress: 1/69, s=578524 t=4896 total=2849405523 cur=16777216
20140923-085443.241: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085443.243: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085443.991: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085444.315: Warning: [GUDE]: Chunk 5 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085444.437: CbJobProgress::SyncProgress: 1/69, s=594193 t=4765 total=2849405523 cur=17825792
20140923-085444.437: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085444.440: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085445.061: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085446.331: CbJobProgress::SyncProgress: 1/69, s=589824 t=4798 total=2849405523 cur=18874368
20140923-085446.331: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085446.334: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085447.225: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085447.575: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085447.737: CbJobProgress::SyncProgress: 1/69, s=762600 t=3703 total=2849405523 cur=25165824
20140923-085447.737: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085447.739: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085448.383: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085448.586: Warning: [GUDE]: Chunk 6 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085449.674: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085450.111: CbJobProgress::SyncProgress: 1/69, s=961194 t=2928 total=2849405523 cur=34603008
20140923-085450.111: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085450.113: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085451.013: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085452.505: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085452.619: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085452.833: CbJobProgress::SyncProgress: 1/69, s=1048576 t=2679 total=2849405523 cur=39845888
20140923-085452.833: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085452.836: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085454.617: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085454.756: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085455.741: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085456.039: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085458.001: CbJobProgress::SyncProgress: 1/69, s=977082 t=2872 total=2849405523 cur=42991616
20140923-085458.001: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085458.004: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085458.645: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085458.645: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085500.139: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085500.954: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085501.249: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085501.366: CbJobProgress::SyncProgress: 1/69, s=1003955 t=2791 total=2849405523 cur=47185920
20140923-085501.366: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085501.369: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085502.610: CbJobProgress::SyncProgress: 1/69, s=1026730 t=2727 total=2849405523 cur=49283072
20140923-085502.610: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085502.613: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085503.000: Informational: [livetype] longpoll: Sending long poll request to https://polka.typekit.com/subscribe?adobe_id=4069332E5309C5EB0A490D45%40AdobeID&entitlemen t_state=6b015fe1d523568761e29b8b748639dacce11756
20140923-085503.000: Informational: [livetype] downloadToFile (id=longpoll) => 5659
20140923-085503.001: Informational: [livetype] onAddParameters
20140923-085503.001: Informational: [livetype] onSetTimeout
20140923-085503.001: Informational: [livetype] longpoll: setting poll timeout to 3600
20140923-085503.007: Informational: [livetype] onAddHeaders (id=longpoll)
20140923-085503.795: CbJobProgress::SyncProgress: 1/69, s=1027176 t=2725 total=2849405523 cur=50331648
20140923-085503.795: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085503.797: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085503.947: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 29 ErrorMessage: Send Request Failed
20140923-085505.323: CbJobProgress::SyncProgress: 1/69, s=1007455 t=2777 total=2849405523 cur=51380224
20140923-085505.324: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085505.326: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085505.537: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085507.207: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085507.207: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085508.599: CbJobProgress::SyncProgress: 1/69, s=990321 t=2823 total=2849405523 cur=53477376
20140923-085508.599: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085508.602: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085509.249: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085509.525: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085509.729: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085510.616: CbJobProgress::SyncProgress: 1/69, s=1011126 t=2762 total=2849405523 cur=56623104
20140923-085510.616: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085510.619: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085510.865: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085511.841: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085512.454: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085513.616: CbJobProgress::SyncProgress: 1/69, s=995258 t=2803 total=2849405523 cur=58720256
20140923-085513.616: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085513.619: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085514.228: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085515.682: Warning: [GUDE]: Chunk 5 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085516.022: Warning: [GUDE]: Chunk 5 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085516.340: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085517.349: CbJobProgress::SyncProgress: 1/69, s=1031931 t=2698 total=2849405523 cur=65011712
20140923-085517.349: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085517.351: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085518.039: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085518.602: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085520.326: CbJobProgress::SyncProgress: 1/69, s=1016800 t=2736 total=2849405523 cur=67108864
20140923-085520.326: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085520.329: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085523.327: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085523.799: CbJobProgress::SyncProgress: 1/69, s=1002985 t=2771 total=2849405523 cur=69206016
20140923-085523.799: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085523.802: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085524.626: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085524.883: CbJobProgress::SyncProgress: 1/69, s=1003637 t=2769 total=2849405523 cur=70254592
20140923-085524.883: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085524.887: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085525.255: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085525.454: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085527.563: CbJobProgress::SyncProgress: 1/69, s=976755 t=2844 total=2849405523 cur=71303168
20140923-085527.563: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085527.567: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085530.031: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085531.142: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085531.639: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085535.577: Warning: [GUDE]: Chunk 5 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085537.558: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085537.716: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085538.804: CbJobProgress::SyncProgress: 1/69, s=861330 t=3224 total=2849405523 cur=72351744
20140923-085538.804: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085538.808: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085541.846: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085541.846: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085542.252: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 29 ErrorMessage: WriteData Failed
20140923-085543.323: CbJobProgress::SyncProgress: 1/69, s=824722 t=3365 total=2849405523 cur=73400320
20140923-085543.324: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085543.327: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085545.019: Warning: [GUDE]: Chunk 4 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085546.003: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085546.777: CbJobProgress::SyncProgress: 1/69, s=809227 t=3429 total=2849405523 cur=74448896
20140923-085546.778: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085546.781: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085548.380: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085548.430: CbJobProgress::SyncProgress: 1/69, s=803164 t=3453 total=2849405523 cur=75497472
20140923-085548.430: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085548.434: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085549.609: CbJobProgress::SyncProgress: 1/69, s=805747 t=3441 total=2849405523 cur=76546048
20140923-085549.609: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085549.613: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085551.178: CbJobProgress::SyncProgress: 1/69, s=821564 t=3371 total=2849405523 cur=79691776
20140923-085551.178: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085551.182: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085551.685: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085552.364: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085552.364: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085553.434: CbJobProgress::SyncProgress: 1/69, s=826150 t=3350 total=2849405523 cur=81788928
20140923-085553.434: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085553.438: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085555.059: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085555.963: CbJobProgress::SyncProgress: 1/69, s=820173 t=3373 total=2849405523 cur=82837504
20140923-085555.963: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085555.966: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085556.922: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085557.787: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085601.066: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085602.252: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 29 ErrorMessage: WriteData Failed
20140923-085603.369: CbJobProgress::SyncProgress: 1/69, s=769597 t=3593 total=2849405523 cur=83886080
20140923-085603.369: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085603.373: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085604.515: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085605.090: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085605.090: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085608.856: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085609.969: CbJobProgress::SyncProgress: 1/69, s=738562 t=3743 total=2849405523 cur=84934656
20140923-085609.970: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085609.973: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085612.780: Warning: [GUDE]: Chunk 2 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085613.760: Warning: [GUDE]: Chunk 3 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085616.932: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085616.933: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085618.252: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 29 ErrorMessage: WriteData Failed
20140923-085619.316: CbJobProgress::SyncProgress: 1/69, s=687865 t=4017 total=2849405523 cur=85983232
20140923-085619.316: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
20140923-085619.318: BaseControllerDelegate::pushSyncProgress {1 of 69 }
20140923-085620.938: Warning: [GUDE]: Request Failed. ErrorCode: 32 errorMessage: Network Error. WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085620.938: [acsl.networking.Retry] [ALWAYS] Retry after 120 seconds as a result of 32 response
20140923-085626.646: Warning: [GUDE]: Chunk 0 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085628.358: Warning: [GUDE]: Chunk 1 failed - Retrying. ErrorCode: 32 ErrorMessage: WriteData Failed. WinHTTP Connection Error. last error code = 12030
20140923-085629.502: CbJobProgress::SyncProgress: 1/69, s=667981 t=4130 total=2849405523 cur=90177536
20140923-085629.502: WControllerDelegate::quota {storageFree:107016441689, storageTotal:107374182400}
