0 Replies Latest reply: Sep 23, 2014 1:13 AM by StefaanVanMieghem RSS
    ALC-ASM-S00-002 NumberFormatException on attachment filename or source
    StefaanVanMieghem Community Member
      DDX:
       <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
        <PDF result="pdfWithAttachments" format="PDF">
         <PDF source="pdfWithoutAttachments"/>
         <FileAttachments source="pic_20140917135051.bmp">
          <File filename="pic_20140917135051.bmp"/>
          <Description>null</Description>
         </FileAttachments>
        </PDF>
       </DDX>
      Error:
      INFO  [com.adobe.livecycle.assembler.AssemblerServiceImpl] ALC-ASM-N00-001: Execute: invoke() begin on thread WorkerThread#1[192.168.126.196:59718] 186
      INFO  [com.adobe.internal.ddxm.Executive] DDXM_N00000: Started processing result named pdfWithAttachments
      ERROR [com.adobe.internal.ddxm.Executive] DDXM_S00001: Failed to assemble result named pdfWithAttachments
      ERROR [com.adobe.livecycle.assembler.AssemblerServiceImpl] ALC-ASM-S00-002: Failed to execute the DDX - error messages provided.
      com.adobe.livecycle.assembler.client.ProcessingException: ALC-ASM-S00-002: Failed to execute the DDX - error messages provided.
       at com.adobe.livecycle.assembler.AssemblerServiceImpl.makeResult(AssemblerServiceImpl.java:906)
       at com.adobe.livecycle.assembler.AssemblerServiceImpl.execute(AssemblerServiceImpl.java:510)
       at com.adobe.livecycle.assembler.AssemblerServiceImpl.invoke(AssemblerServiceImpl.java:454)
      Caused by: java.lang.NumberFormatException: For input string: "20140917135051"
       at java.lang.NumberFormatException.forInputString(Unknown Source)
       at java.lang.Integer.parseInt(Unknown Source)
       at com.adobe.internal.pdfm.embeddedfiles.EmbeddedFilesHandler.updateBaseDocEmbeddedFilenames(EmbeddedFilesHandler.java:947)
       at com.adobe.internal.pdfm.embeddedfiles.EmbeddedFilesHandler.addEmbeddedFile(EmbeddedFilesHandler.java:691)
       at com.adobe.internal.pdfm.embeddedfiles.EmbeddedFilesHandler.importEmbeddedFiles(EmbeddedFilesHandler.java:285)
       at com.adobe.internal.pdfm.attachments.Attachments.importAttachments(Attachments.java:370)
       at com.adobe.internal.ddxm.task.attachments.ImportAttachments.execute(ImportAttachments.java:216)
       at com.adobe.internal.ddxm.ddx.Node.execute(Node.java:353)
      The assembler is parsing the filename or source string (not sure which) and cast the timestamp part to a number ??
      The assembler proces works fine with source and filename "pic_1.bmp"
      Livecycle ES2.0
