1 2 Previous Next 48 Replies Latest reply on Jun 6, 2018 1:09 PM by Valkyrie Anne
    How do I get the actual signature to show in a document using XI?
    sign forms Level 1
      Been using Adobe for years and with the new update to XI I am having a heck of a time getting the signature to show in the document.  To check this I opened another document and was easily able to grab my signature and place it where I want.
      For some reason the document I was sent allow for me to sign electronically, but when I choose to do so, I'm asked first to draw a box to where the signature is to be placed, then another dialog box opens asking for the file.  I was not able to find a place to add a new signature by using the methods used previously.  I have a signature in a file and has been used many times for other .pdf docs with zero issues.
      Not sure why this doc is giving me issues.  The document sent to me is showing its from Adobe 7.x! Not sure if that is the issue, as it could be the problem placing the signature.
      Please advise to try and get this resolved.
        • 1. Re: How do I get the actual signature to show in a document using XI?
          Perhaps the document is expecting a DIGITAL signature rather than a stamp?
          • 2. Re: How do I get the actual signature to show in a document using XI?
            Steven.Madwin Adobe Employee
            Let's start with what application you are using (it's not Adobe because Adobe is a company, not a product). Is it Acrobat or is it Reader? If you are on Windows you can get the information from the Help > About <application name> menu. On the Mac it would be the Acrobat or Adobe Reader menu and then About <application>. Once you get the about screen up you will see a version number. If you can let me know what that is as well that would be great (I know you said the major version is 11, I'm also curious as the the minor version number).
            Steve
            • 3. Re: How do I get the actual signature to show in a document using XI?
              sign forms Level 1
              I am using Adobe Reader IX.  I have version 11.0.09.  It looks to be the latest version.
              The document I received had a signature on it from another person.  Clearly visible.  When I attempt to add mime, I am first asked to highlight an area where the signature should be placed.  Then I am asked to pick the signature I want to use.  If I use the standard name it appears in block letters.  If I select create a new one, there is no place for the signature to go.  Another option is for the file, but having no idea where that might be.  I am not given an option to scan, photo, or hold up my signature to the camera.
              Just looking for a way for this to work as it did on other docs.
              • 4. Re: How do I get the actual signature to show in a document using XI?
                Please let me know which dialog you are seeing.
                Is this the dialog you are seeing?
                    Figure 1: Place Signature
                Or is it this dialog?
                    Figure 2: Drag New Signature Rectangle
                Steve
                • 5. Re: How do I get the actual signature to show in a document using XI?
                  sign forms Level 1
                  Figure #2
                  It asks for the placement rectangle first.  Then another pop up asks me to choose which one I want to use.  I tried to create a new one, but that only takes me to another page where I input my info.  It does show me an option to choose a file, if I only knew where that was!  I guess once I find it, I can use it!  What would a signature extension be?
                  • 6. Re: How do I get the actual signature to show in a document using XI?
                    I assume when you say "another pop up" you really mean that your seeing this dialog...
                    Let's start with some nomenclature so we are on the same page. What you are trying to do is create a "digital signature" and in order to do that you need a "digital ID". To think of this in physical world terms, the PDF file is a piece of paper, the digital ID is the pen and the digital signature is, well the signature. In order to create a digital signature you must have something to sign with, and that something is a public-key based digital ID. This digital ID can reside in several places. It can be in a password protected file and the file would have either P12 or PFX as the file extension to the file name. The digital ID could be locked onto a token or smart card, in which case you would get access to it using a PIN instead of a password. It could also be locked into the Operating System. On Windows that would be the Windows Certificate Store (think of "store" in this case as storage, not a market place), and on the Mac it would be the Keychain Access application.
                    So the question is, do you currently have a valid digital ID (they do expire) or do you need to procure one? My guess is you need to procure a new digital ID and this is where you are being tripped up.
                    If you do need to procure a new digital ID, the next question is, do you need to get a high assurance digital ID from a trusted 3rd-party Certificate Authority (you, as the signature creator are the 1st party, and whomever you send the signed PDF file to is both the signature recipient, and also the 2nd party). The thing that makes a Certificate Authority (CA) trusted is because they will do identity vetting in order to ensure that you are who you say you are before they issue you a digital ID. When you get a digital ID from a CA you can think of it as a drivers license or password, not for what they allow you to do (drive a car or cross a border), but rather as a trusted and generally accepted piece of identification. Yes, a digital ID issued to you from a CA allows you to sign data just like a pen, but more importantly it acts as a trusted piece of identification. All that said, if you don't need a high assurance digital ID that proves you are who you say you are, then you can create your own digital ID. In that case the digital ID is really just a pen for signing and does not provide any trust regarding your identity. The advantage to creating your own digital ID is it's quick, easy, and free. The downside to getting a digital ID from a CA is it is time consuming and not free.
                    Since your have started down the path of creating your own digital ID already let's finish with that workflow and leave it for later to see if that meets the identity requirements of whomever you are sharing the signed file with. If you are seeing the dialog above select the bottom radio button next to "A new digital ID I want to create now", and then click the Next button. The contents of the next dialog you see is as dependent on whether you are on Mac or Windows. On Windows the next dialog asks you where you want to save the digital ID, either in a password protected file, or in the Windows Certificate Store. If you select the File option you will be asked to provide the password every time you sign a PDF file, whereas with the Windows option when you log into Window that provides the authentication to access the private key in the digital ID and thus when you sign a PDF file you won't be asked to provide a password. If you are on a Mac since saving the digital to a file is the only possible option this dialog is skipped. The next dialog is where you enter the information that you want contained in the digital ID that identifies you as the signer. If you've already filled out the Identity panel on the Preferences dialog then that data will be pulled in, but if not you you are going to need to add at a minimum a Name and an Email address, and then click the Next button. If you are saving the digital ID in a file, the next order of business is to pick a location where you want to save the file you are about to create and assign it a password to protect the private key from unauthorized access.  You're now on the last dialog for digital ID creation so you can click the Finish button.
                    This takes you to the Sign dialog. If you already had a valid digital ID to sign with you would have seen this dialog right after you inscribed the signature field and would have shipped all of the digital ID creation dialogs. If you saved your new digital ID in a file the Sign dialog will ask you to provide the password you just used (don't forget this password because you'll need it when you want to sign files at some later date). Enter the password and click the sign button. You'll be asked where you want to save the signed file (you can overwrite the existing file if you like, or you can save it as a new file), and once you've done that you'll have a digitally signed PDF file.
                    Steve
                    • 7. Re: How do I get the actual signature to show in a document using XI?
                      SkipperGreg Level 1
                      I think there is a different problem going on since I am experiencing the same issue as the original post.  I have Acrobat 11.0.09 on Windows 8.1 and prior to a recent update I simply clicked the "Place Signature" button and a TRANSPARENT signature (using an image I had previously assigned in preferences/signature) was put on the document.  Now, since the software was updated, when I click the same "Place Signature" button instead of overlaying the signature I have to create a signature block and then go through all the stuff you detail in your reply, Steve.  That is new in a recent release.  To make matters worse the new signature is not transparent it's opaque.  I recall this is how Acrobat standard used to work a long time ago.  Is there a way to go back to the transparent signature placement I saw in earlier versions of Acrobat 11?
                      • 8. Re: How do I get the actual signature to show in a document using XI?
                        Hi Greg,
                        There a couple of different concepts that I fear are getting merged into one generic "signature" conversation blob. Let me start with some definitions:
                        A digital signature - A cryptographic operation based on using a digital ID that provides both proof of document and signer integrity. The actual signature is a blob of encoded and encrypted data written into the PDF file, but it may reference a field in the document that is a graphical representation of the signature, and is known as the signature appearance.
                        An electronic signature - An imaged added to a page in the PDF file that is a graphical representation of a "wet ink" signature. There is no cryptographic assurance that the signature is valid, or, what has purportedly been signed has not been altered. What you see on the page is all there is and there is no validation to check integrity.
                        It sounds like you were using an earlier major version of Acrobat or Reader (by major version I mean the "11" part of 11.0.9. The zero dot nine is the minor version) and when you upgraded to version 11 (or XI as you see it in the marketing branding) you lost the link to the image file you were using in version 10 or earlier.
                        It seems to me (correct me if I'm wrong) that you are trying to create an electronic signature with a image file that had the background opacity set to 0% so the background of the image did not obstruct the view of the text on the page. If you don't know where the original image file is you're not going to be able to use it in version 11. If you do know where it is you can do the following:
                        • Open the Fill & Sign pane on the toolbar
                        • Expand the Fill & Sign Tools panel
                        • Mouse over Place Signature and then select the drop-down menu by clicking the down-arrow button on the right
                        • Select Change Saved Signature from the drop-down menu
                        • Select the Use an image radio button
                        • Click the Browse button to the right of the File Name edit field
                        • Navigate to, and select the image you would like to use, and then click the Open button
                        • Click the Accept button on the Place Signature dialog
                        At this point your mouse cursor is your signature. Click on the page wherever you'd like the electronic signature to appear and Acrobat will then revert to the normal editing mode.
                        Steve
                        • 9. Re: How do I get the actual signature to show in a document using XI?
                          SkipperGreg Level 1
                          Thank you very much Steve.  I have new info that I think points toward a bug in the latter version.  First, regarding your reply, yes I'm trying to create a transparent electronic signature using the "Place Signature" button and do not want the digital signature.  This was working in a previous release of Acrobat 11 as I wanted it to but in a more recent release it lost the link to the image like you said but then forced me to create a signature block, digital ID, etc.  I never saw the "How would you like to create your signature" window you reference above.  When I created the digital ID I chose local file.
                          While waiting for a reply to above I tried some things that may prove there is a bug here.  I deleted the digital ID.  I then created a new digital ID and told it to use Windows this time.  I then created a PDF and tried using the "Place Signature" button.  Once again it created a digital signature block which is not what I wanted and I had no other choice.  I then clicked the "Place Signature" button a SECOND time and the desired electronic signature transparent overlay appeared.  I created a new PDF and now every time I click "Place Signature" I get the desired transparent e-signature I had in earlier releases.  So, something was "stuck" and by creating a second digital signature it was unlocked.  Sounds like a bug to me.
                          • 10. Re: How do I get the actual signature to show in a document using XI?
                            sign forms Level 1
                            Yes, its the electronic signature we are after.  That one would float over to where you needed it placed and released the mouse and dropped it on the line.
                            That is the one I was looking to use.  The digital signature only places what look like block letters on the line and some other info on the right.  I also tried to create a new digital ID but was not able to use the mouse as a pen as was not an option.
                            Sounds like we are getting close to the bottom of this nonsense.
                            Hope this helps
                            • 11. Re: How do I get the actual signature to show in a document using XI?
                              Hi Greg,
                              If upgrading from and earlier version of 11 to 11.0.9 caused the Place Signature tool to lose it's settings that would be a bug. I'll see if I can reproduce that behavior.
                              That said, it seems that Place Signature now thinks it's default setting is to create a digital signature whereas you want it to be an electronic signature. What you need to do clear the settings and reset the default by selecting the drop-down menu just to the right of the button proper, and then select Change Saved Signature from the drop-down menu. That will allow you to chose a different option than a certificate based digital signature.
                              Steve
                              • 12. Re: How do I get the actual signature to show in a document using XI?
                                Hi Sign Forms,
                                You definitely don't want to create a digital ID if what you are looking for is an electronic signature. You, like Greg above, seem to be in a situation where the Place Signature default is locked onto the certificate based digital signature workflow. Follow what I mentioned directly above and see if that gets you into the desired state.
                                However, and as an aside, should you ever decide to adopt the use of certificate based digital signatures for security purposes there are options to customize the signature appearance so it does not display the block letters you mentioned.
                                Steve
                                • 13. Re: How do I get the actual signature to show in a document using XI?
                                  sign forms Level 1
                                  I would like, or rather use the digital version and yes I would like to be able to see it like the electronic one!  How do you do that?
                                  "However, and as an aside, should you ever decide to adopt the use of certificate based digital signatures for security purposes there are options to customize the signature appearance so it does not display the block letters you mentioned."
                                  • 15. Re: How do I get the actual signature to show in a document using XI?
                                    archipel06 Level 1
                                    hello,
                                    i have a similar problem after upgrading to 11.0.09:
                                    i use a digital ID from an USB Key to sign differents documents, without any problems for years, and after upgrading, Acrobat pro can't find my digital ID.
                                    how could i solve this problem?
                                    Eric
                                    • 16. Re: How do I get the actual signature to show in a document using XI?
                                      sign forms Level 1
                                      Steve,
                                      These links seem to direct me to Adobe Acrobat pro.  I have Adobe Reader, so it appears that some of the suggestions do not apply.  I tried to follow one of the links through google and found that the settings are not available to users of the version of Adobe I'm using.  The tutorial had under Security, a place to change or add or edit a signature, not so under Security in Reader.  There is a separate place for signature and it winds you back to the same screen I have inside the document when I attempted to sign it.  Argh!
                                      Frustrating to say the least.
                                      • 17. Re: How do I get the actual signature to show in a document using XI?
                                        Hi Eric,
                                        One thing that since the beginning of digital signatures in Acrobat/Reader the app didn't process the Extended Key Usage (EKU) extension, but that was remedied with version 11.0.9. Now, in order to be able to use a digital ID for signing a PDF file, the digital ID must not be limited to its use via the EKU. My guess is (and since this was the only change to signing in 11.0.9), you are trying to sign with a digital ID whose purpose has been limited by the issuing CA because they add a value to the EKU.
                                        Please follow these steps to get the usage setting and then let me know what they are:
                                        • Select the Edit > Preferences menu item
                                        • Select Signatures from the Categories list box
                                        • Click the More button in the Identities & Trusted Certificates group box (the third button from the top)
                                        • Highlight your digital ID in the list box and then click the Certificate Details button on the toolbar
                                        • Highlight the text in the Intended Usage field on the Certificate Viewer dialog and copy the text
                                        You can then paste that text into your reply and I can then explain why the digital ID is not allowed for signing.
                                        Steve
                                        • 18. Re: How do I get the actual signature to show in a document using XI?
                                          Hi sign forms,
                                          Proviso: This is harder without Acrobat to do some editing and image-to-PDF conversion.
                                          Let's start with the infrastructure of a signature appearance field. The field has two layers, a background and a foreground.  The foreground is additionally divided in half with the left half displaying graphics and the right half displaying text. If there is no graphic as part of the signature appearance then the whole of the foreground becomes one big text field. The same thing applies going the other way, if there is no text then the whole of the foreground becomes one big graphics field.
                                          The default background is the pink PDF trefoil logo. You have an option (we'll get to it in a bit) of not displaying the background at all, but you also have the ability to change the background image. If you want to use your own logo you need to put it in a PDF file, name the file SignatureLogo.pdf and save it to C:\Users\<user name>\AppData\Roaming\Adobe\Acrobat\11.0\Security\. You would want to crop the PDF page (you need a PDF editing toll such as Acrobat, you can't do this in Reader) so it is pretty much just the image, otherwise the logo will be too small when displayed in the signature field.
                                          To create a custom foreground appearance follow these steps:
                                          • Click the More button in the Creation & Appearance group box (the topmost button)
                                          • Click the New button in the Appearances group box
                                          Here is another place you are going to be limited as a Reader user as you can only import a PDF file as an imported graphic. Reader does not have the ability to process image files like Acrobat does, thus all you can import are PDF files.
                                          It's on this dialog that you also have the ability to turn the background on & off via the Logo checkbox. As you turn items on and off you will see the Preview box reflect the changes.
                                          Here's an example of where I changes the background to a picture of a rubber duck, made the left side of the foreground a scanned image of my wet ink signature, and made the right side (the text side) of the foreground only have the Date and Version number:
                                          Steve
                                          • 19. Re: How do I get the actual signature to show in a document using XI?
                                            SkipperGreg Level 1
                                            Steve, I'm sure all the steps you outline are helpful but the fact that for a while I was locked into "digital signature" mode and then somewhat arbitrarily I was reverted back to "electronic signature" mode implies some sort of bug since I did none of the things you suggest.
                                            For the original poster, all I can offer are the steps I took after I saw the same thing you saw:
                                            . my Adobe Acrobat XI updated and out of nowhere when I "Placed Signature" it asked to draw a box and create a digital signature whereas before it overlayed a transparent e-sig.
                                            . I went into preferences/signatures and in one of the 4 settings buttons where it shows your digital IDs I deleted all that I could.
                                            . I created a new digital ID and instead of clicking the option to save locally I said use Windows
                                            . I the "Placed Signature" and again was required to create a box and digital signature but I did it anyway in a PDF.
                                            . I then "Placed Signature" a SECOND time in the same PDF and then out of nowhere it no longer asked me to create a box but I saw the transparent e-signature I used to see in older releases of Acrobat 11.
                                            . From this point forward I got the eSignature as desired.
                                            Good luck.
                                            • 20. Re: How do I get the actual signature to show in a document using XI?
                                              archipel06 Level 1
                                              Thanks Steven,
                                              here is the text from the Intended Usage field:
                                              "Signature de transaction, Signature de document, Authentification du client"
                                              Thanks for your help
                                              Eric
                                              • 21. Re: How do I get the actual signature to show in a document using XI?
                                                Hi Eric,
                                                The first two items (and I'm going to do this in English) ; Sign Transaction, and Sign Document are from the Key Usage extension (they represent the "digital signature" and "non-repudiation" bits respectively). Their presence limits the use of the digital ID to signing anything other than certificates and CRLs. If there was no Extended Key Usage (EKU) extension present you would still be able to sign a PDF file. However, the last item on the list (Client Authentication) is from theEKU extension and it tells the processing applications (in our case Acrobat & Reader) that the digital ID is further restricted to allowing the client (in other words, your computer) to authenticate to a server or system.
                                                A bit about digital IDs. They are issued by trusted third party Certificate Authorities (CAs) and it's the CA that determines for what purpose a digital ID that they have issued may be used. The CA controls what goes into the usage, constraints, and policy extensions, and together those extensions define and narrow the purpose a the digital ID. The CA is governed by a set of policies and practices that are defined in publicly available documentation, and their whole existence is dependent on not varying from those rules. If they say (through the cert extensions) that they want the digital ID limited to a particular operation then it is incumbent on the  processing application (again, in our case that means Acrobat and Reader) to respect those limitations.  Yes, Acrobat used to ignore the EKU and that was a flaw in Acrobat. As you may imagine, ignoring the EKU caused problems for certain users and thus brought this flaw to light, which is why it was fixed in version 11.0.9.
                                                The bottom line is, you need to coordinate with the CA that issued you your certificate and procure a new digital ID that is not restricted to client authentication. The three things that may be in the EKU that would allow signing of a PDF file are ; Allow Any, Email Security, and Code Signing. If the CA were to add one of those to the EKU along with Client Authentication, then you will be able to sign again.
                                                Steve
                                                • 22. Re: How do I get the actual signature to show in a document using XI?
                                                  archipel06 Level 1
                                                  Thanks Steve,
                                                  I will follow your advice
                                                  eric
                                                  • 23. Re: How do I get the actual signature to show in a document using XI?
                                                    adobeforumuser72
                                                    Hello Steve,
                                                    thanks for very thorough explanation, but to be absolutelly sure ... Certificate designed for Client Authentication cannot be used for document signing., Correct?
                                                    BTW: mine says this ... (crazynumber - OID is SmartCard Logon)
                                                    Intended usage: Sign transaction, Encrypt keys,
                                                    1.3.6.1.4.1.311.20.2.2, Client Authentication
                                                    Windows Store Cert Info:
                                                    Milos
                                                    • 24. Re: How do I get the actual signature to show in a document using XI?
                                                      Hi Milos,
                                                      Correct, Client Auth does not enable the cert for PDF signing, and for that matter neither does Smart Card Logon .
                                                      There are a a lot of little bits to consider. A certificate with neither the Key Usage (KU) extension nor the Extended Key Usage (EKU) extension is to be considered good for every and all possible operations that a certificate can be used for. Once the certificate authority (CA) adds one, or both, of those two extensions they are in essence limiting the use of the certificate. Where things get a bit messy is coming to the realization that the two extensions (KU & EKU) are processed separately. Both (if they are both present) must allow for signing a PDF, or more correctly, neither must disallow signing a PDF.
                                                      In the case of your certificate, the KU does allow for signing a PDF because it has the "Digital Signature" value, but the EKU does not allow for signing a PDF because it does not contain one of the three values (Allow Any, Email Protection, or Code Signing) that we require. At least one of those three values has to be there if the EKU is present for the certificate to be able to sign a PDF file.
                                                      All of these rules are defined in the internationally accepted standard RFC 5280, sections 4.2.1.3 & 4.2.1.12.
                                                      Steve
                                                      • 25. Re: How do I get the actual signature to show in a document using XI?
                                                        diber001 Level 1
                                                        im also trying to use my electronic signature but to no avail. when my "place signature" window opens it does nto allow me to select any choice other than "use a certificate"  what gives?  never had issues before.  11.09 on windows 7
                                                        • 26. Re: How do I get the actual signature to show in a document using XI?
                                                          Hi diber001,
                                                          If the PDF file already contains a signature field, then the author of the document expects you to sign using a certificate (that is, create a cryptographically secure digital signature) and not use an annotation based unsecured electronic signature, and thus, all of the other options on the Place Signature dialog are disable other than the Use a certificate option.
                                                          Steve
                                                          • 27. Re: How do I get the actual signature to show in a document using XI?
                                                            okeeweekee Level 1
                                                            Hi Eric,
                                                            I have the same that you, when i try to sign with a certificate embbeded in a smartCard (https://forums.adobe.com/message/6852903)
                                                            Have you found a solution a this problem ?
                                                            Best regards
                                                            • 28. Re: How do I get the actual signature to show in a document using XI?
                                                              okeeweekee Level 1
                                                              Hi  Steve,
                                                              If i undestand on the version of Adobe Reader 11.0.9, you have implemented a dual control for sign a file. In the step you check that you the bit the Key Usage Digital signature is present AND the Extented KU  CodeSigning OR EmailProtection is present ?
                                                              But the chapter of RFC5280  4.2.1.2.12 explain that :
                                                              " if a certificate contains both a key usage extension and an extended keu usage extension, than both extensions MUST be processes independently and the certificate MUST only be used for a purpose consistent with both extensions. If there is no purpose with both extensions, then the certificate MUST not be used for any purpose."
                                                              The fact do not have the EKU with CodeSigning OR EmailProtection  induces a failure to sign a document with Acrobat reader ?
                                                              it Is corrects ?
                                                              Laurent
                                                              • 29. Re: How do I get the actual signature to show in a document using XI?
        Hi Laurent,
        The lack of the EKU extension does NOT prevent signing in Acrobat or Reader.
        When the certificate authority (CA) issues a certificate, they have certain controls as to how to limit the use of that certificate and those controls are the extensions that they may add to the certificate at cert creation time. However, there is nothing that says they have to limit the usage. If they (the CA) elects not to added any limitations then the certificate is considered good for any and all digital signature based operations.
        At a minimum, there is one limitation that always is placed on a certificate, and that is its validity period. No matter how long you make the life of the certificate it will expire at some point at which point it has reached a time limitation. Other that the expiration date there are other items that the CA may add to the cert in the form of extensions that tell the processing application (in our case that would be Acrobat & Reader) how to limit the use of the cert. It's not just the KU and EKU that can limit the use of a cert. For example there are constraints (path, name, basic) and policies which would also limit the use of the cert.
        With regard to the KU and EKU, the CA doesn't have to add either of those two extensions, but if they do it is incumbent Acrobat and Reader to respect the limitations the CA has imposed. If the CA adds the KU extension, then that particular extension must contain either the "digital signature" or the "non-repudiation" value in order for the cert to be considered good for signing a PDF file. Other values could be included in the KU, but at a minimum one of those two I listed must be present. They can both be there as they are not mutually exclusive, but at least one of them has to be there IF the KU is included in the cert.
        If the CA adds the EKU extension, then that particular extension must contain either the "any allowed", "e-mail protection", or "code signing" values. Again, and like the KU, any one value will suffice, and they can all be there, but at least one of them must be included in the EKU.
        Steve
        • 30. Re: How do I get the actual signature to show in a document using XI?
        11llopetz Level 1
        There is definitely something funky with the 11.0.9 upgrade, unfortunately it persists through the 11.0.10 upgrade.  I am running pro.  My Fill & Sign and Comment toolbars are now totally blank.  Going in to manage signatures as suggested here causes the program to consistently crash.  Tried repairing the install already - no change.  This stinks.
        • 31. Re: How do I get the actual signature to show in a document using XI?
        hablutzel1 Level 1
        I have just read A: Changes Across Releases — Digital Signatures Guide for IT, where the new recent EKU processing you mention is explained. Nevertheless nothing is indicated about the Adobe Acrobat & Reader behaviour when validating a signature already created with a certificate with an incompatible EKU. And I have just tested this behaviour in the new Adobe Acrobat Pro DC v2015.007.20003 and the already created signature (with a certificate with an incompatible EKU) is being validated normally. Are you planning on an eventual change in the verification behaviour?
        • 32. Re: How do I get the actual signature to show in a document using XI?
        dave.martin Level 1
        Thank you for your very comprehensive and clear explanation of the situation with Digital Signatures and Electronic Signatures!! I really learned a lot from reading the entire thread from last fall.
        I.. unlike it seems most of the posters in this thread... started using Adobe Acrobat Pro XI and had no problems whatsoever using what I learned from this discussion is an electronic signature.  My goal was and is to be able to sign an editable PDF Document with a scanned version of my pen and ink signature and email it to my company.  I had no problem whatsoever doing that with Version XI. I just clicked on Sign, and dragged my scanned signature (which is in a .JPG file) to the signature line with my trackpad (I am using a MacBook Pro) and aligned it how I wanted it and dropped it... done!
        Now since I "upgraded" to Adobe Acrobat Pro DC" this no longer works and when I select Fill and Sign from the tools I get a message in the upper right corner of the window saying: ""Get Started:  You have opened a fillable PDF form.  This form does not let you drag and drop saved information".  This always worked in XI using the very same fillable PDF file I am using now... I hope you can tell me how to make it work in DC and/or report it as a bug if it can't work.
        Otherwise I guess I will have to downgrade to XI since I need this to work. That is the whole reason I subscribed to Acrobat Pro... to be able to sign and send by email this document without having to print it, sign it manually, and then rescan it into a new PDF document.  Especially when I am traveling and don't have easy access to a printer and scanner!
        I have spend several hours on phone support and chat support and even sharing my screen with several Adobe Technicians without any of the technicians being able to come up with a solution.  Certainly none of them appeared to have your comprehensive knowledge about signatures!
        I hope you can help me resolve this!!
        • 35. Re: How do I get the actual signature to show in a document using XI?
        askacfi Level 1
        No. The morons who replied are engaged in a form of brainiac trolling....they keep telling you all about "digital signatures" which have ZERO to do with what you are seeking to accomplish...they are too smart by half to understand a simple question or they are actually trolling by responding with meaningless information.
        I, like you, simply seek to insert my scanned signature into the document. I DON'T WANT OR NEED A DIGITAL SIGNATURE.
        I like you, used to be able to simply insert my scanned signature at the bottom of documents and email them right back without having to print, manually sign, scan and return.....the idiots above are not able to conceive of a world wherein the recipient may not need, care, be able to use a digital signature...the recipient just needs your scanned signature on the document.
        I get it. You would need to spell it out in baby speak in order to make any headway into the hard heads of the trolls who have thus far replied to this thread.....
        Like you, if I cannot figure out a way to insert my scanned signature I will downgrade too....
        • 36. Re: How do I get the actual signature to show in a document using XI?
        askacfi Level 1
        complete 100% NON response by a brainiac nerd who does not comprehend the English language
        • 37. Re: How do I get the actual signature to show in a document using XI?
        askacfi Level 1
        • 38. Re: How do I get the actual signature to show in a document using XI?
        askacfi Level 1
        Don't be a moron steve
        ok?
        Because the question was to seek how, in the newest version...assume today steve...Acrobat Pro DC, to place a SCANNED IMAGE OF THE USERS SIGNATURE INTO THE DOCUMENT....HELLO? ANYBODY HOME? NOTHING NOTHING NOTHING TO DO WITH DIGITAL SIGNATURES....GETTING THROUGH YET?
        JUST ASSUME THE USER WANTS TO INSERT THE HANDWRITTEN LETTERS "Abcd Defgh" at or near the bottom of documents...again steve...assume he neither wants nor needs 'digital signatures'...get it yet steve?
        do they pay you btw?
        my response to the user is as follows:
        • 39. Re: How do I get the actual signature to show in a document using XI?
        askacfi Level 1
        1 2 Previous Next
