1. Re: Cannot add variable in Likert Quiz
Lilybiri Sep 23, 2014 9:11 AM (in response to Maerix)Which variable did you try to insert? And what do you mean by '...rate it...'? Can you explain more in detail.
2. Re: Cannot add variable in Likert Quiz
Maerix Sep 23, 2014 10:29 AM (in response to Lilybiri)hi,
i'm using a simple user variable. On the first slide i've 4 different text entry box use to ask "which are 4 top problems you need to fix with a management software?"
After typing those 4 "problems" in the text entry box we went to reuse those "problems" at the end of our presentation and ask the same people to rate us if our solution can fix their "problems" . using a Likert style raring scale.
tks to help me !
3. Re: Cannot add variable in Likert Quiz
Lilybiri Sep 23, 2014 11:06 AM (in response to Maerix)How do you want to present the 'Likert style' at the end? And what do you want to get as result from that 'Likert...' thing? You can use the Radiobuttons Interaction to create a scale, next to text containers in which you add the variables populated at the start. Maybe post a screenshot of the mockup?
