2 Replies Latest reply on Sep 24, 2014 5:06 AM by resdesign
    Acces element in a ChildSymbol created progamatically
    Benoit Leray Level 1
      after hours reading API and forums, I'm still stuck doing the following.
      First I create Child Symbol of order in my Symbol Content which in on main comp.
      sym.getComposition().getStage().createChildSymbol("order", "content");
      In my Child Symbol order I got a div element named step1 I would like to get control on.
        sym.getComposition().getStage().getSymbol("content").children("order").$("step1").html('m y Text');
      What is the common path to access ChildElement create by creatChildSymbol ?
      Thanks .createChildSymbol
        • 1. Re: Acces element in a ChildSymbol created progamatically
          Siva. Level 3
          Dynamically created objects return their reference. You can use them later.
          // Creates an instance of  "order" inside "content"
          var order_inst1 = sym.getComposition().getStage().createChildSymbol("order", "content");
          // "step1" is an element of order_inst1
          order_inst1.$("step1").html('m y Text');
          • 2. Re: Acces element in a ChildSymbol created progamatically
            resdesign Adobe Community Professional & MVP
            Hello,
            The way that has worked for me is to assign a new id to the element. For  example I have a symbol called 'button'. I create it on the Stage then I assign an id to it. Then I can use the symbol with the new ID with the # in front of it.
                var button = sym.createChildSymbol("button", "Stage");
                button.element.attr("id","newButton");
                sym.$('#newButton').css({
                    "position"            :"absolute",
                    "top"                 :Pos[i].y,
                    "left"                :Pos[i].x,
                    'cursor'                :'pointer'
