1 Reply Latest reply on Sep 24, 2014 1:23 AM by Mylenium
    Can't select keyframes
    licensehappy
      I have gone trough this tread with no luck:
      I'm working on a project manly with images. Basically keyframing position and scale. At some point, totally random, i'm unable to select my keyframes. Noting changed in comp.
      This is what happends. Set scale to 80%, move keframe to the left. Set scale to 100% move keyframe to right. Select first keyframe and move a bit more to left. Select second keyframe and move a bit more to right. Try to select first keyframe, no luck. Try to select second keyframe, no luck. Now i can't select any scale keyframe on that image. Nothing works. If i disable and reable the stop watch, the problem will start again at random point. Need help!
