1. Re: Why does a navigate in the TOC not call the On Enter of the same slide?
RodWard Sep 24, 2014 2:16 AM (in response to Kretus)The on slide enter event only fires when you enter a slide fro anther slide.
2. Re: Why does a navigate in the TOC not call the On Enter of the same slide?
TLCMediaDesign Sep 24, 2014 2:27 AM (in response to Kretus)You could set a variable "jumpSlide" in an advanced action, set the variable, then jump to a "dummy slide" that has a onEnter action that jumps to the slide contained in the jumpSlide variable. This will allow you to jump to the same slide and fire the onEnter action.
3. Re: Why does a navigate in the TOC not call the On Enter of the same slide?
Kretus Sep 24, 2014 2:32 AM (in response to TLCMediaDesign)How can I set an advanced action on a navigation event in the TOC? Is that possible?
4. Re: Why does a navigate in the TOC not call the On Enter of the same slide?
Lilybiri Sep 24, 2014 3:41 AM (in response to Kretus)Not possible. TLCMediaSolution is OK, but will not help if I understand your question correctly: when you click on the same slide as the present slide in the TOC. Or maybe I misunderstand?
Maybe you'll have to look for another work flow? Why not add a replay slide button?
5. Re: Why does a navigate in the TOC not call the On Enter of the same slide?
Kretus Sep 24, 2014 4:03 AM (in response to Lilybiri)Yes, it happens when you click on the same slide as the present slide in the TOC. There is a replay button present on the slide, But it is still possible to open the TOC and navigate. I cannot prevent the user from navigating to the same slide as the present slide apparently...
6. Re: Why does a navigate in the TOC not call the On Enter of the same slide?
TLCMediaDesign Sep 24, 2014 4:36 AM (in response to Lilybiri)Sorry, I forgot the navigation was from the TOC. My minds a little foggy due to meds since I cut the top of my thumb off!
It does work if you make a dummy for every slide and apply the goto Next slide onEnter of all the dummies. You'd need to devise a formula to display slide numbers correctly, but it does work if you deselect all of the "real" slides in the TOC..
