0 Replies Latest reply on Sep 24, 2014 7:08 AM by dfkurz
    STILL NEED HELP - Problem with creating a cross reference
    dfkurz Level 1
      I asked this yesterday but received no replies:
      I have created a cross reference to a heading in the same document. I want to be be able to have this function just a like a link - when you click on it in the pdf exported from the ID file, you jump to that spot in the doc (this doc will be read online). I created the cross reference easily - it shows the text I am linking to and the page number correctly. But it does not function as a link in the pdf. I have tried setting up the cross reference with the Link to Paragraph, as well as Link to Text Anchor options. Neither of them work. (But if I select the "Go To Destination" menu option in the Hyperlinks panel in InDesign, it jumps directly to the correct spot).
      I am used to working in FrameMaker, and this function is quite easy to do in Frame. I know I must be missing some obvious and simple step, but I am stumped.
