2 Replies Latest reply on Apr 5, 2007 8:13 AM by soodonimus
    Volume Slider
    soodonimus
      Hello, I have created a volume slider with a button that starts in the center. When I drag the button left, the volume increases. When I drag right the volume decreases. How do I change the volume so that dragging left will decrease the sound and dragging right will increase the sound?
      onClipEvent (load) {
      top = _y;
      bottom = _y;
      center = _x;
      left = center - 40;
      right = center + 40;
      onClipEvent (enterFrame) {
      if (dragging == true) {
      this._parent.mySound.setVolume(100-((_x-center)*2.5));
        • 1. Re: Volume Slider
          Level 7
          "soodonimus" <webforumsuser@macromedia.com> wrote in message
          news:ev1cft$e84$1@forums.macromedia.com...
          > center.
          > volume
          > the
          > top = _y;
          > bottom = _y;
          > center = _x;
          > left = center - 40;
          If I understand, you start the button in the center, which I assume is 50%
          volume?
          If you are setting the registration point to the upper left then...
          left = _x;
          right = _x + _width;
          If it is the center then...
          left = _x - _width / 2;
          right _x + _width / 2;
          Then...
          var gotoLocation = 100 * (_right - _x ) / _width
          this._parent.mySound.setVolume(gotoLocation);
          NOTE: Not tested...
          • 2. Re: Volume Slider
            soodonimus Level 1
            Thank you! Yes, I want the button to start in the center at 50% volume. I see that the variable controls the volume direction. I want the volume to decrease when I slide left and increase when I slide right, so here is the final code:
            top = _y;
            bottom = _y;
            center = _x;
            left = center - 40;
            var gotoLocation = 100*(left-_x)/40;
