13 Replies Latest reply on Sep 25, 2014 3:17 PM by kglad
    Smooth movement of Background
    andersonlipa Level 1
      Hi can anyone help me, I want to know what action to have a result like this site http://www.radicaltesta.com/index_d.php
      I can do everything but leave the smoothest navigation, that's my jam. If anyone can give me the action of smooth motion I would be very happy for the help. Thank you
        • 1. Re: Smooth movement of Background
          var easeSpeed:Number = .5;
          your_bg.cacheAsBitmap=true;
          this.addEventListener(Event.ENTER_FRAME,f);
          function f(e:Event):void){
          your_bg.x = easeSpeed*your_bg.x+(1-easeSpeed)*mouseX;
          your_bg.y = easeSpeed*your_bg.y+(1-easeSpeed)*mouseY;
          • 2. Re: Smooth movement of Background
            Hi friend its action seems to work. I want to add your command line in this code. Could you help me because I can not add your command within my event, if you can write a new command line fixing problems I would be very happy.
            import flash.events.MouseEvent;
            addEventListener(MouseEvent.MOUSE_MOVE, Bg_mov);
            function Bg_mov(e:MouseEvent):void{
              var distX:Number = stage.stageWidth - bg.width;
              var distY:Number = stage.stageHeight - bg.height;
              var quantX:Number = mouseX / stage.stageWidth;
              var quantY:Number = mouseY / stage.stageHeight;
              var posX:Number = distX * quantX;
              var posY:Number = distY * quantY;
              bg.x = posX;
              bg.y = posY;
            • 3. Re: Smooth movement of Background
              that code won't yield smooth movement.
              use the code i suggested and adjust the speed parament (between 0 and 1) to control the speed of momement.
              • 4. Re: Smooth movement of Background
                Its action seems to work but yet always starts at x0 and y0, also seems to leave so the stage background. Is there any way to leave as in the example Mentioned site? In the example objects interact with the bg and remain within the stage, also when the mouse is moved the opposite way will move as it goes to +x and-x. You can pass me this action? Please help me.
                . RADICAL TESTA - ESTRATEGIA .
                • 5. Re: Smooth movement of Background
                  yes, define your parameters:
                  var leftLimit:int
                  var rightLimit:int
                  var upLimit:int
                  var downLimit:int
                  var easeSpeed:Number;
                  paramF(your_bg,'xMove',leftLimit,stage.stageWidth,right,rightLimit,0);
                  paramF(your_bg,'yMove',upLimiit,stage.stageHeight,downLimit,0);
                  your_bg.x = easeSpeed*your_bg.x+(1-easeSpeed)*(your_bg.xMove.m*mouseX+your_bg.xMove.b);
                  your_bg.y = easeSpeed*your_bg.y+(1-easeSpeed)*(your_bg.yMove.m*mouseY+your_bg.yMove.b);
                  function paramF(mc:MovieClip,s:String,x1:Number,y1:Number,x2:Number:y2:Number):void{
                  mc[s].m=(y1-y2)/(x1-x2);
                  mc[s]=b=y1-mc[s].m*x1;
                  • 6. Re: Smooth movement of Background
                    Thank you for your effort to help me but I need you to help me writing all the action or command des its beginning, because I'm new to Flash am having difficulties. If you can do this I will be grateful. Thank you
                    • 7. Re: Smooth movement of Background
                      i did.
                      • 8. Re: Smooth movement of Background
                        I did as mentioned, I have the following errors:
                        Scene 1, Layer 'Action', Frame 1, Line 15 column 25 1158: Syntax error: missing left brace ({) before the function body.
                        Scene 1, Layer 'Action', Frame 1, Line 20 column 68 1084: Syntax error: expecting colon before rightparen.
                        • 9. Re: Smooth movement of Background
                          use:
                          var leftLimit:int
                          var rightLimit:int
                          var upLimit:int
                          var downLimit:int
                          function f(e:Event):void{
                          function paramF(mc:MovieClip,s:String,x1:Number,y1:Number,x2:Number,y2:Number):void{
                          • 10. Re: Smooth movement of Background
                            Thank you for your effort in helping me, but I'm having a lot of mistakes here compiler.
                            • 11. Re: Smooth movement of Background
                              that should be:
                              kglad wrote:
                              use:
                              var leftLimit:int
                              var rightLimit:int
                              var upLimit:int
                              var downLimit:int
                              paramF(your_bg,'xMove',leftLimit,stage.stageWidth,rightLimit,0);
                              mc[s].b=y1-mc[s].m*x1;
                              p.s. you need to define those parameters.
                              • 12. Re: Smooth movement of Background
                                You could write the complete action for me with the parameters and everything. My Bg has the name "bg"
                                • 13. Re: Smooth movement of Background
                                  the appropriate parameters depends on your reg points and personal preferences.  there's no easy way to determine those via a forum.
                                  if you want to hire me to do this for you, send me a personal message.
