1. Re: Trouble with Cross-References
saprentice Sep 24, 2014 5:20 PM (in response to ohnehosen)Hi ohnehosen...
Are you up to date on your FM11 patches? It's hard to say what could be causing this problem .. does sound strange.
While this shouldn't be the problem, you might try linking your xref to the container "topic" element (topic, concept, task, whatever is the immediate parent of the title you're pointing at). While in theory you should be able to xref to a title, that's not really the intent, your cross-ref is referencing a "topic" not the title within the topic. The same goes for a figure or table, you reference the fig or table element not the title within those elements.
I'd assume that the code in the FM-DITA plugin was designed to work by referencing the container ,it probably wasn't tested the way you're doing it, and there may be some flakiness that would cause this to not always work.
Give it a try .. let us know how it goes.
…scott
2. Re: Trouble with Cross-References
ohnehosen Sep 25, 2014 8:14 AM (in response to saprentice)Hi Scott,
I gave this a try on one of my "trouble" xrefs, and it seems to have worked. I can't remember exactly why I was linking to titles, but I seem to remember there was some reason for it...Anyway, this seems to be working for now. Thanks again for your help.
3. Re: Trouble with Cross-References
saprentice Sep 25, 2014 1:58 PM (in response to ohnehosen)Great .. I'm glad that seems to be doing the trick. People often start by linking to titles, because that's what they think they need to do, but it's really not a good idea.
Cheers!
