5 Replies Latest reply on Sep 25, 2014 8:01 PM by muttaqinmn
    [ASK] Footer
    muttaqinmn
      Hi, I am drafting a document. In my old document I used Ms. Word.
      I used footer in every pages. In footer of current page usually uses words of the first line of the next page (as shown in the figure). I wrote manually, so it took time.
      Could you suggest me how to make footer as I mention above in InDesign?
      Many hanks and best regards.
        • 1. Re: [ASK] Footer
          First words of the next page is a bit unusual, and unfortunately it doesn't quite fit into the things you can do with a running header variable (you can read about variables in the help files), so I don't see a way around having to enter this text manually SOMEWHERE on your page, either in the footer area or a non-printing tag that could be picked up by a variable, which means it isn't a practical method for automation.
          Maybe someone else has an idea...
          • 2. Re: [ASK] Footer
            Obi-wan Kenobi Level 5
            Aha! Very funny!
            If you only want:
            "sebagai …"
            [Apparently, you have an auto-numbering para style!]
            Yes we can!
            Otherwise [JS] can handle it!
            • 3. Re: [ASK] Footer
              I'm curious how you plan to have this automatically update during editing....
              • 4. Re: [ASK] Footer
                Hi Peter,
                I did not say it would be "in live"!
                When the page layout is complete, then we take care of footers [before, we'll take the opportunity to remove all the hyphens between pages // with script!]
                That said, handling is simple and takes 1/2 minute(s) [script + grep] but it has some limitations [as I said]. If the layout moves, you can do it again easily!
                Before unveiling how I've imagined it, I would wish javascripters' thoughts! Thanks for comments.
                • 5. Re: [ASK] Footer
                  muttaqinmn Level 1
                  Actually, I just knew the term yesterday, it is "catchwords". In Word, I got idea from Catchwords in footer.
                  But, I have no idea in script or GREP in InDesign.
                  So please.
