5 Replies Latest reply on Sep 25, 2014 6:56 AM by Arihant Jain Mg
    Pagewise export of all text
    Arihant Jain Mg
      How to export all text as .txt or .rtf based on pagewise?
      Regards
        • 1. Re: Pagewise export of all text
          Sajeev Sridharan Level 4
          1) Run "SplitStory.jsx" javascript file (javascript files will be available in "Scripts Panel\Samples\JavaScript" location)
          2) Run "ExportAllStories.jsx"
          3) Each an every page will be exported as a separate word document
          Note: If each page have multiple stories then it will also exported as a separate word document.
          Vandy
          • 2. Re: Pagewise export of all text
            Arihant Jain Mg Level 1
            I tried your solution but it exports a lot of extra files. I even tried running Merge_Textframes_ID.jsx before exporting. And the file order is not according to the page.
            Is there a way to save text only from the current page?
            Regards
            • 3. Re: Re: Pagewise export of all text
              Try this,
              var myWindow = new Window ("dialog", "Export DOC");
              myWindow.orientation = "row";
              var myInputGroup = myWindow.add ("group");
              myInputGroup.add ("statictext", undefined, "Enter your Page Number:");
              var myPage = myInputGroup.add ("edittext", undefined, "");
              myPage.characters = 10;
              myPage.active = true;
              var myButtonGroup = myWindow.add ("group");
              myButtonGroup.orientation = "column";
              myButtonGroup.add ("button", undefined, "OK");
              myButtonGroup.add ("button", undefined, "Cancel");
              var myResult = myWindow.show ();
              if (myResult == 1)
                  for(i = 0; i < app.activeDocument.pages[Number(myPage.text)-1].textFrames.length; i++)
                      myFileName = "Page_" + myPage.text + "_"  + i + ".rtf";
                      myFilePath = "/d/word_files/" + myFileName;
                      myFile = new File(myFilePath);
                      app.activeDocument.pages[Number(myPage.text)-1].textFrames[i].texts[0].exportFile(ExportFormat.RTF, myFile);
              Vandy
              • 4. Re: Pagewise export of all text
                Works perfectly. Thank you so much.
                However I m facing an issue, I am trying to export unicode (hindi) content & after exporting the content goes missing. English characters are exported properly but unicode characters are not exported. Is there any solution to the unicode issue?
                Sample text
                अरिहंत
                Thanks for all the help
                Regards
                • 5. Re: Pagewise export of all text
                  Just append at the bottom
                  with(app.textExportPreferences){
                      //Options for characterSet: TextExportCharacterSet
                      characterSet = TextExportCharacterSet.UTF8;
