2 Replies Latest reply on Apr 19, 2007 7:27 AM by lon46
    Can no longer see connection
    pfhyper
      I was administering two sites in Contribute. After using Windows to uninstall Contribute 3, I installed Contribute 4. Only one site is now listed but when I try to create a connection for the other site, Contribute tells me I am already connected. But there is no listing of the site on Contribute home or in the My Connections dialog. Is there a setting file somewhere that I need to delete?
      I am running Windows XP.
        • 1. Re: Can no longer see connection
          lukaro Level 1
          I am not sure of the solution, but bear in mind that when you connect to sites on your server, Contribute does create a _mm folder in which there is a contribute.xml file that stores settings relating to the site. I don't know whether altering this file or even deleting it could solve your problem but it is worth further investigation.
          Rgds
          lukaro
          • 2. Re: Can no longer see connection
            lon46
            Hello Hidden Connection:
            I'm not sure if this is the solution to your problem but it was the solution to mine.
            Scenario: I had a ftp website to connect and it continuously said I already had a connection.
            It was not listed in the my connections though. I removed registry and files related to this connect as well as disconnected
            temporarily from Homesite. The resolution, inspired by you two, (since I looked here as well) was to
            go to My Connections / Administer / Web Server - Here you will find alternate addresses for each website (possibly)
            When I deleted these, I was able to connect appropriately.
