1 Reply Latest reply on Apr 23, 2007 2:45 PM by VarioPegged
    old problem: the render CheckBox works wrong.
    01robert Level 1
      hi all,
      [I posted this question several days ago, but have not gotten the answer. I think I did not make the problem clear. So repost it again]
      I put a checkBox as a datagrid's render, it works well at the first time. After I changed the selectedValue and refresh the datagrid, It selected the checkboxes randomly.
      Any suggestion will be appreciated!
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:DataGrid x="177" y="68" dataProvider="{myList}" editable="true">
      <mx:columns>
      <mx:DataGridColumn headerText="name" dataField="name"/>
      <mx:DataGridColumn headerText="isTrue" dataField="isTrue"/>
      itemRenderer="mx.controls.CheckBox"
      rendererIsEditor="true" editorDataField="selected"
      <!--rendererIsEditor="true" editorDataField="selected"-->
      </mx:columns>
      </mx:DataGrid>
      <mx:Button label="refresh" click="resetList()" x="240" y="38"/>
      <mx:Script>
      <![CDATA[
      import mx.controls.CheckBox;
      import mx.collections.ArrayCollection;
      [Bindable]
      private var myList:ArrayCollection=new ArrayCollection();
      private function resetList():void{
      var arr:Array=[{name:"test1", isSelected:true}
      ,{name:"test3", isTrue:true}
      ,{name:"test2", isTrue:true}];
      myList=new ArrayCollection(arr);
      </mx:Script>
      </mx:Application>
        • 1. old problem: the render CheckBox works wrong.
          VarioPegged Level 2
          Here's a solution that may work for you. It uses a value object's "isTrue" property to bind to your Checkbox's "selected" property. This solution is almost exactly Derrick Grigg's Checkbox solution, with the exception of instantiating the VOs in a for loop from your original array.
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="resetList();">
          <mx:Script>
          <![CDATA[
          import valueobjects.ValueObject;
          [Bindable]
          private var myList:ArrayCollection;
          var arr:Array = [{name:"test1",isTrue:true}, {name:"test3",isTrue:true}, {name:"test2",isTrue:true}];
          myList = new ArrayCollection()
          var myItem:ValueObject;
          var len:int = arr.length;
          for (var c:int=0;c<len;c++) {
          myItem = new ValueObject();
          myItem.name = arr[c].name;
          myItem.isTrue = arr[c].isTrue;
          myList.addItem(myItem);
          </mx:Script>
          <mx:DataGrid x="177" y="68" dataProvider="{myList}">
          <mx:columns>
          <mx:DataGridColumn headerText="isTrue" dataField="isTrue">
          <mx:itemRenderer>
          <mx:Component>
          <mx:CheckBox click="data.isTrue=!data.isTrue" selected="{data.isTrue}" />
          </mx:Component>
          </mx:itemRenderer>
          </mx:DataGridColumn>
          </mx:columns>
          </mx:DataGrid>
          </mx:Application>
          and the ValueObject class is something simple like (saved as ValueObject.as in package valueobjects):
          [Bindable]
          public class ValueObject
          public var name: String;
          public var isTrue: Boolean = false;
          public function ValueObject()
          Hope that works for you
