1. Re: Multiple answer survey question with no correct answer - just click all that apply. (C8)
Lilybiri Sep 25, 2014 1:04 PM (in response to SusannNutter)What do you want exactly? There is a Likert question (maybe not available for responsive project) or you could use a MCQ set to Survey instead of Graded?
2. Re: Multiple answer survey question with no correct answer - just click all that apply. (C8)
SusannNutter Sep 25, 2014 1:10 PM (in response to Lilybiri)I have a MCQ with 11 options to select (click all that apply) (multiple answers). It's set to survey - not graded. It still registers 1 correct answer and when I take the question, it reports it as failed in the Quiz results screen if I mark other than the "correct" answer it indicates. I'm also having the same problem with a single response MCQ .
3. Re: Multiple answer survey question with no correct answer - just click all that apply. (C8)
Lilybiri Sep 25, 2014 1:19 PM (in response to SusannNutter)That is very strange . Alternative is to create a custom question, using the Radiobuttons interaction or the Checkboxes interaction. What do you want to do with the result?
4. Re: Multiple answer survey question with no correct answer - just click all that apply. (C8)
SusannNutter Sep 25, 2014 1:22 PM (in response to Lilybiri)Just have the answers recorded in the LMS, allowing the LMS to report appropriate info.
