16 Replies Latest reply on Jul 7, 2015 8:39 PM by sarahm71398705
    CE_COPY_NOT_ALLOWED
    Rob_Stolk
      When I move / copy a downloaded E-book with Adobe Digital Editions from my laptop to my Kobo e-reader I get the message: CE_COPY_NOT_ALLOWED. What can I do about it?
        • 1. Re: CE_COPY_NOT_ALLOWED
          tsmith163
          How are you attempting to copy the book? Is it through a USB transfer, or through the software (ADE or Kobo) itself?
          • 2. Re: CE_COPY_NOT_ALLOWED
            Rob_Stolk Level 1
            I downloaded the book from the community library, cklick-right on the download and choose "open with Adobe Digital Editions". The book appears in my bookcase. (I can now read the book on my laptop)
            When I drag the book to the icon of the connected Kobo-reader (left side of the screen), the message "CE_COPY_NOT_ALLOWED" appears.
            When I copy the book from my Downloads and paste it in my e-reader a message appears on the e-reader: "This file cannot be openend. It is protected by Adobe DRM and is not accessible with your Adobe ID. Sign in with your authorised Adobe ID and try again."
            I have no idea what to do.
            • 3. Re: CE_COPY_NOT_ALLOWED
              Marmotdad62
              Hey Rob. I'm having the same problem as you with my NOOK. Were you able to figure it out?
              • 4. Re: CE_COPY_NOT_ALLOWED
                KenRCarson Level 1
                I downloaded an ebook from library and can read on computer ok but get this copy not allowed-no permission to copy the book when I try to put it on my Libre eBook reader...help please?
                • 5. Re: CE_COPY_NOT_ALLOWED
                  reellis67
                  These all sound like DRM issues, based on what I've seen. Most public library loans do not allow you to read ebook files on multiple devices unless you get them from a special service like Freeding because of publisher required DRM encoding (which frustrates librarians just as much as it frustrates you.) For example, I can borrow an ebook from my public library, read it on my Mac in Adobe Digital Editions, but I can't put it on my Kindle e-ink reader because the DRM will not allow me to change it's format. When you try to copy a file from A.D.E. to a device it will often try to convert the file to a format that is compatible with the device, an action that is typically prevented by DRM encoding.
                  That said, if you get ebooks from the public library using a service called Freeding (something that not all libraries provide, but many do) there is no DRM on the ebooks so they can be transferred to a device for easier reading. If you get a typical library loan and select Adobe Digital Editions you will likely only be able to read it on that computer unless you have a device that has either the Digital Editions software or app installed.
                  - R
                  • 6. Re: CE_COPY_NOT_ALLOWED
                    tsmith163 Level 1
                    Can you open the file in Adobe Digital Editions and go to File > Item Info and check what the file says for "viewing" and "copying" under permissions?
                    • 7. Re: CE_COPY_NOT_ALLOWED
                      KenRCarson Level 1
                      It says viewing on any device until 2014-10-13, (normal library time
                      period), and "not allowed" for copying
                      • 8. Re: CE_COPY_NOT_ALLOWED
                        Rob_Stolk Level 1
                        In my case it says:
                        viewing and copying on any device until 17-10-14
                        2014-09-30 22:52 GMT+02:00 tsmith163 <forums_noreply@adobe.com>:
                            CE_COPY_NOT_ALLOWED  created by tsmith163
                        <https://forums.adobe.com/people/tsmith163> in Adobe Digital Editions - View
                        the full discussion <https://forums.adobe.com/message/6778742#6778742>
                        • 9. Re: CE_COPY_NOT_ALLOWED
                          assen2
                          What I did to resolve this issue is:
                          1. Crated a second ADE account
                          2. Open ADE and under 'Devices' find your reader and from the upper right corner  select “Authorize Device ”
                          3. Use the second ADE account
                          4. Copy the book
                          Rds,
                          Assen
                          • 10. Re: CE_COPY_NOT_ALLOWED
                            Rob_Stolk Level 1
                            Yes! Problem solved. Thank you very much!!!!
                            2014-10-01 20:46 GMT+02:00 assen2 <forums_noreply@adobe.com>:
                                CE_COPY_NOT_ALLOWED  created by assen2
                            <https://forums.adobe.com/people/assen2> in Adobe Digital Editions - View
                            the full discussion <https://forums.adobe.com/message/6781796#6781796>
                            • 11. Re: CE_COPY_NOT_ALLOWED
                              KenRCarson Level 1
                              When  I look at the area under devices it shows as being authorized.  Not
                              sure what you mean be creating a second account...how do I do that?
                              Thks, Ken
                              • 12. Re: CE_COPY_NOT_ALLOWED
                                tsmith163 Level 1
                                I believe he is referring to creating a second Adobe ID which can be done here:
                                Sign up - Adobe ID
                                • 13. Re: CE_COPY_NOT_ALLOWED
                                  Kobohelp
                                  I have the same CE_COPY_Not_Allowed message and it is driving me crazy.  I do not want to read my library book on my desktop computer, but on my KOBO device.  I do not understand create a second ADE account, which one of the posters then explained as "creating a second Adobe ID".  But when I went to the link, my name and email address and password were there so how do I create a second Adobe ID.   Do I put in a fake name, with my email address and then a new password?  Will that not confuse Adobe?  I am certainly confused.
                                  • 14. Re: CE_COPY_NOT_ALLOWED
                                    vinsanity92
                                    I've used this before years ago, same process. I borrow the ebook from the library website, open it with ADE and i can read it on my laptop. Now I'm having the "copy not allowed" issue transferring it to my nook tablet. When I used this last, it went through no problem so I don't think its an issue because of the library book. Please help
                                    • 15. Re: CE_COPY_NOT_ALLOWED
                                      Sgt3355
                                      Hi, I followed the advice above "Can you open the file in Adobe Digital Editions and go to File > Item Info and check what the file says for "viewing" and "copying" under permissions?"
                                      But the message I get "The document is licensed for a different user account"!!!!!!!
                                      There is only one user, me!!! There has only ever been one user, me!!
                                      I have spent hours on this, and quite honestly I feel like throwing the KOBO in the bin and buying a good old paper book
                                      The software is written by morons
                                      • 16. Re: CE_COPY_NOT_ALLOWED
                                        sarahm71398705
                                        This solved all my problems.  When I tried to authorize my computer or my ereader before it said that my id could only be used to authorize 1 computer or device.  This is the same computer and ereader I had authorized and used before, but for some reason now it said it was not using an id.  I created an new account with another email address and authorized both the computer and ereader with it and everything went fine.  I am now able to transfer my library books to me ereader.
                                        Thank you !
