1. Re: Noise and colorspace
mikeengles Sep 26, 2014 3:45 PM (in response to mikeengles)Hello
Well no replies and I am not surprised.
I have to say I did not explain very well or provide any images.
In essence I seem to be seeing differences between how Lightroom exports files and opens for editing the same files in an external editor, Photoshop.
Also the onset of noise using the threshold seems different for each Color space.
I will have to investigate further.
Mike Engles
2. Re: Noise and colorspace
Jao vdL Sep 26, 2014 9:50 PM (in response to mikeengles)You should realize that 128 has a very different meaning in adobeRGB and prophotoRGB than it has in sRGB. They encode different brightnesses in the different color spaces so it is not at all a surprise that you see different results and a necessary result that has little to do with what Lightroom does.
3. Re: Noise and colorspace
mikeengles Sep 27, 2014 3:55 AM (in response to Jao vdL)Hello
Thanks for the reply.
Yes, that makes sense as the threshold for AdobeRGB and sRGB are very close, but very different for ProPhotoRGB.
I suppose it is because of the gamuts that they encompass.
I am still not convinced that Lightroom's export and edit transfer to Photoshop are the same.
I am still checking.
Mike Engles
4. Re: Noise and colorspace
Jao vdL Sep 27, 2014 7:33 AM (in response to mikeengles)Mike,
It’s not just the gamut. A main difference for this purpose is in the color space’s gamma curve. prophotoRGB has a 1.8 gamma, while sRGB uses a complex gamma curve ( http://lagemaat.blogspot.com/2008/06/srgb-tone-curve-and-lightroom-color.html ) that is close to gamma 2.2 but not quite. AdobeRGB assumes a gamma curve with exponent 563/256, which is practically 2.2. adobeRGB does not have the linear part near zero which causes it to be very different in the dark regions from sRGB. This all means that 128 in any of the color channels encodes for a brightness that is 32% higher in prophotoRGB than in sRGB and adobeRGB so you can’t really compare equal numbers. What you have to do is afterwards in Photoshop, convert to another color space and compare there. if you are using 8-bit files, you might find some posterization in the pro photo files that is simply due to the much wider color space being used with only 256 levels.
5. Re: Noise and colorspace
mikeengles Sep 27, 2014 3:18 PM (in response to Jao vdL)Hello
Thanks for the reply and explanations. I never use ProPhoto, but it is interesting to know that its native gamma is 1.8.Is there a relationship between this and the old Apple RGB?
This had a native gamma of 1.8 as was also the case with Apple displays. I am not sure if Apple displays are still gamma 1.8.
Now I only use Adobe RGB, but obviously need to convert to sRGB for using images in the Web.
My main interest in this is to work out if camera sensor noise is more noticeable in sRGB that Adobe RGB.
I did have the sense that sensor noise was more apparent in sRGB, because it was darker.
Mike Engles
6. Re: Noise and colorspace
Andrew Rodney Sep 27, 2014 4:33 PM (in response to mikeengles)mikeengles wrote:
Other than the gamma and both are RGB working spaces, none.
Maybe this pair of free video's will help, after you might consider ProPhoto RGB, especially part three of the first that talks about what a wider gamut working space provides in shadows of saturated color you can capture:
The benefits of wide gamut working spaces on printed output:
This three part, 32 minute video covers why a wide gamut RGB working space like ProPhoto RGB can produce superior quality output to print.
Part 1 discusses how the supplied Gamut Test File was created and shows two prints output to an Epson 3880 using ProPhoto RGB and sRGB, how the deficiencies of sRGB gamut affects final output quality. Part 1 discusses what to look for on your own prints in terms of better color output. It also covers Photoshop’s Assign Profile command and how wide gamut spaces mishandled produce dull or over saturated colors due to user error.
Part 2 goes into detail about how to print two versions of the properly converted Gamut Test File file in Photoshop using Photoshop’s Print command to correctly setup the test files for output. It covers the Convert to Profile command for preparing test files for output to a lab.
Part 3 goes into color theory and illustrates why a wide gamut space produces not only move vibrant and saturated color but detail and color separation compared to a small gamut working space like sRGB.
High Resolution Video: http://digitaldog.net/files/WideGamutPrintVideo.mov
Low Resolution (YouTube): https://www.youtube.com/watch?v=vLlr7wpAZKs&feature=youtu.be
Everything you thought you wanted to know about color gamut:
A pretty exhaustive 37 minute video examining the color gamut of RGB working spaces, images and output color spaces. All plotted in 2D and 3D to illustrate color gamut.
High resolution: http://digitaldog.net/files/ColorGamut.mov
Low Res (YouTube): http://www.youtube.com/watch?v=n0bxSD-Xx-Q
7. Re: Noise and colorspace
Nikhil Varma Sep 27, 2014 11:39 PM (in response to Andrew Rodney)I have yet to see these videos, but I wonder:
If my Camera has no ProPhoto setting, only sRGB and AdobeRGB, will it matter to use ProPhoto (convert to Pro photo RGB space), when my originals are in a lower (less info) color space?
8. Re: Noise and colorspace
elie-d Sep 28, 2014 1:46 AM (in response to Nikhil Varma)If you shoot in Raw, that camera setting is irrelevant because it applies only to jpgs made by the camera. Raw files are greyscale data files and therefore have no color and no color space. The color is created by Lightroom. At the time of outputting a rendered RGB image, either with Export or Edit In..., you choose the color space in which it will be rendered.
If, OTOH, you are editing jpgs in Lightroom, you could increase the saturation and thus create new (artificial) colors in the image that are beyond the gamut of the original jpg's space. Saving the new jpg in ProPhoto RGB would preserve those colors.
BTW, a smaller gamut does not mean "less info". It means the same amount of data refers to a narrower range of colors.
9. Re: Noise and colorspace
Jao vdL Sep 28, 2014 7:14 AM (in response to Nikhil Varma)elie is right. The camera setting has no bearing on the final result from Lightroom if you shoot raw. It has only very limited effect if you shoot jpeg. You'll likely not be able to notice the difference in the jpeg case except perhaps if you have highly saturated colors in the image. Flowers are a good example. But again, the setting is not used at all when you shoot raw. In fact it is one of the most confusing settings in cameras that really for raw files should be disabled but I doubt camera makers will do that.
FYI, the way Lightroom works is that it regardless of the source file format, raw, jpeg, tif, psd, or png, and regardless of the source file's color space (if it is non-raw) renders the image into a 16-bit color space that has prophotoRGB primaries and a linear gamma. This ensures no posterization artifacts can occur. This means that for raw files, you always get the entire gamut the camera can capture and more if you consider that vibrance, saturation, and such can send the colors far further into lala land. These colors are rather unlikely to run out of the linear prophotoRGB space as that is incredibly wide gamut. It then converts the file from the linear prophotoRGB space to whatever color space it needs to output, be it sRGB, adobeRGB or 1.8 gamma prophotoRGB for export, or the display profile for displaying or a printer profile for sending to a printer. In all cases, you'll get the best representation from the native linear prophotoRGB space. This includes any noise present in the original, which will go through all these conversion steps and will come out the other end the same regardless of the output color space. It will just be as faithfully represented as the target space will allow.
10. Re: Noise and colorspace
mikeengles Sep 28, 2014 8:53 AM (in response to Andrew Rodney)Hello
Many thanks for those video links, I have downloaded them as I really could not see much difference in the Youtube low res versions.
MDE
11. Re: Noise and colorspace
ssprengel Sep 28, 2014 2:07 PM (in response to mikeengles)You can change the YouTube videos to 1080P HD if you think that’d help make them less low-res.
