1 Reply Latest reply on Sep 27, 2014 4:57 AM by JimHess
    I have a CS4 and would like to install Camera Raw 8.6. How do i do it?
    morpheus2004 Level 1
      I have a CS4 and would like to install Camera Raw 8.6. How do i do it? The reason being in LR5 when I want to edit the images in Photoshop Layers, the message comes that I need to install Camera Raw 8.6 for compatibility.  Even
      After installing Camera Raw 8.6 I am unable to install the plugin in CS4. Please advice.
        • 1. Re: I have a CS4 and would like to install Camera Raw 8.6. How do i do it?
          Camera Raw 8.6 is only compatible with Photoshop CS6 and Photoshop CC. There is no way for you to install it in Photoshop CS4.  The message you are receiving means that you need Camera Raw 8.6 to have full compatibility with Lightroom 5. But in that message you are given the option to edit a copy that includes the Lightroom adjustments. That is the option that you should use. Lightroom will create a copy (PSD or TIF, depending on your choice in Lightroom preferences) and will send that copy to Photoshop CS4. Then you can use Photoshop and all of its features to continue editing your image. When you close and save the image in Photoshop, it will appear in your Lightroom folder along with the original raw file.
          Another option you could use would be to use the free Adobe DNG converter to create DNG (digital negative) copies of your raw files. Those DNG files would be compatible with the Photoshop that you have now. Your other option would be to upgrade your Photoshop.
