3 Replies Latest reply on Oct 5, 2014 8:45 AM by nikste
    LR5 Performance menue development (Entwicklung)
    nikste
      Hello,
      i've a problem with the performance of LR5. If i change to the register "development" (German "Entwicklung"), the
      raktion by clicking on the meneu botton, it needs about 5 seconds, until the menue will open.
      In each other register, i've no problems. Can any help?
      Hardware:
      ATI 6core, 3,2 Ghz
      8MB memory
      Graphiccard ATI ENGTX550TI
      Windows 7 64bit
      BR
      nikste
        • 1. Re: LR5 Performance menue development (Entwicklung)
          Ian Lyons MVP & Adobe Community Professional
          By design, accessing the Develop module for the first time after launching Lr will be slow (typically 3 - 5 seconds). Are you seeing the delay the first time after launching Lr or every time you access the Develop module?
          • 2. Re: LR5 Performance menue development (Entwicklung)
            nikste Level 1
            It's every time. By checking this, i've note following:
            - by clicking the menue (f.e. "settings"), it need about 4-5 seconds
            - by changing between the different menues (picture, settings, tool), the dropdown change imediatly, but if go to "view" it needs about 4 seconds, until the dropdown apears
            - it is equal, from which side i go to this menue (tools=>view ord windows=>view)
            - by leaving "view" it works mostly good
            nikste
            • 3. Re: LR5 Performance menue development (Entwicklung)
              nikste Level 1
              Hello,
              after nobody could help me, i've triede to solve the problem by my self. So, i deinstalled all
              vesions of LR and install LR5 from the original CD.
              On this point, after installing LR5, it works good, but only as administrator. If i use a user-login, it doesn't work
              For information:
              i use different log-ins:
              -Administrator for Installing and service
              -User log-ins for different user without administrator right!
              So is install LR5.6 and it works without problems, if i start the program as "administrator"
              Perhaps ist help it to solve other problem
              Best Regards
              nikste
