5 Replies Latest reply on May 10, 2006 7:55 PM by Newsgroup_User
    Why aren't my other music files working!?!?
    DumbFudge Level 1
      Here's the code...
      // initialize starting track
      var soundNext:String = "beats01";
      // set up dynamic sound object
      var dynamicSound:Sound = new Sound(this);
      dynamicSound.attachSound(soundNext);
      dynamicSound.start(0, 1);
      nowPlaying.text = soundNext;
      beats01.onRelease = beats02.onRelease = beats03.onRelease = beats04.onRelease = beats05.onRelease = beats06.onRelease = beats07.onRelease = beats08.onRelease=function () {
      soundNext = this._name;
      nextTrack.text = soundNext;
      // trigger next sound
      dynamicSound.onSoundComplete = function() {
      // stop the timeline
      stop();
      beats05-08 aren't working. I press the button and it gives the name of the song but plays the current one instead. Could it be because the first 4 are the same size while the last 4 vary?
      He's random other code.
      function drag() {
      this.startDrag(false, -50, -50, 50, 50);
      this.onEnterFrame = function() {
      pan = 2*this._x;
      vol = 50+this._y;
      loopSound.setPan(pan);
      loopSound.setVolume(vol);
      this._parent.pan.text = pan;
      this._parent.vol.text = vol;
      this.onMouseMove = function() {
      updateAfterEvent();
      function drop() {
      this.stopDrag();
      delete this.onEnterFrame;
      delete this.onMouseMove;
        • 1. Re: Why aren't my other music files working!?!?
          DumbFudge Level 1
          Uh... help please.
          The first 4 sounds (beats01-04) work fine. When I press the buttons for them they work fine and go on to the needed song.
          I can't find out why my next four songs aren't working...
          It's annoying.
          • 2. Re: Why aren't my other music files working!?!?
            DumbFudge Level 1
            I've gotta have this done in like an hour... The last part that I can't find out... HELP!
            I think it has something to do with this code:
            Not sure though.
            • 3. Re: Why aren't my other music files working!?!?
              jthereliable
              Try renaming the beats05 to something else or something... like rename beats05 to beats01 and beats01 to beats05. If there is a problem with the things after 04, then it shouldn't play. But if it does play and doesn't play beats01, I don't know what's wrong. It seems to look correct... (maybe it's the buttons?)
              • 4. Re: Why aren't my other music files working!?!?
                TimSymons Level 1
                Did you make sure to export beats05 - 08 for actionscript in the library? This is a common mistake I make...more than I would care to admit.
                Tim
                • 5. Re: Why aren't my other music files working!?!?
                  Level 7
                  "DumbFudge" <webforumsuser@macromedia.com> wrote in message news:e3tv5q$7gk$1@forums.macromedia.com...
                  > out... HELP!
                  > Not sure though.
                  Quick test of your code.. it works fine. Must be a problem with linkage names for the sounds in the library like TimSymons said, or
                  you forgot to put instance names on those 4 buttons for beats05 to beats08.
                  I would do the button assignments a different way, but it works either way if the sound and button objects exist.
                  for (a = 1; a<= 8; a++)
                  var btn = this["beats0"+a];
                  btn.onRelease = function()
                  tralfaz
