5 Replies Latest reply: Sep 30, 2014 1:16 AM by Mister_Mitbewohner RSS
    Strange error: "Handler not found in object: #newObject" (at a sprite object)
    Mister_Mitbewohner Community Member
      Hi there,
      I'm facing a strange error in Lingo. I'm using Director 11.5 on Windows 7.
      First I was reconstructing a tutorial for netConnection in Director. This worked fine.
      Then I added some further functionality and then - a strange error occured where nothing much has been altered and which was working fine before. Now Lingo doesn't know the handler "newObject" at the sprite pSprite anymore! Why???
      The regarding code for this error is a behavior for the button to connect. The code is the following:
      global pNetConn
      global gUserList
      property pSprite
      on beginSprite (me)
        pSprite = sprite(me.spriteNum)
        pSprite.cursor = 280
      end beginSprite
      on mouseDown (me)
        sIch = me.stripSpaces( sprite(3).text )
        put "eigener Name ist: "& sIch
        if ((sIch = "") or (sIch = void)) then
          alert "Bitte geben Sie Ihren eigenen Namen an."
        else
          gNameSelbst = sIch
          if voidP(pNetConn) then
            me.setConnection()
          end if
          me.getUserList()
          go frame(23)
        end if
      end mouseDown
      on setConnection me
        pNetConn = pSprite.newObject("NetConnection")
        pSprite.setCallback(pNetConn,"onStatus",#statusUpdate,me)
        pSprite.setCallback(pNetConn,"clientListChannel",#userListUpdate,me)
          tURL = "rtmp://xxxxxxxx"
        pNetConn.connect(tURL)
      end setConnection
      on statusUpdate aArg1, aArg2
        if (aArg2.code = "NetConnection.Connect.Success") then
          -- Hier erfolgt später die Sendung des eigenen Videostreams an den Server
        end if
      end statusUpdate
      on userListUpdate aArg1, aArg2
        luserList = aArg2
        if   (luserList <> void) then
          put "-----USER-LIST UPDATE------"
          gUserList = []
          repeat with counter = 0 to luserList.length -2
            sname = luserList[counter].label
            gUserList.add(sname)
          end repeat
        end if
      end userListUpdate
      on stripSpaces (me, aString)
        -- clear all spaces from the string
        repeat while offset(SPACE,aString)
          tCharIndex = offset(SPACE,aString)
          delete aString.char[tCharIndex]
        end repeat
        -- return the string
        return aString
      end
      The tutorial code which works is the following:
      Here the netConnection is built in the on exitFrame - but I already tried this in my new code above without any success. By the way, I intentionally xxx-ed the URL ;-) Of course in the original there's a correct server adress.
      global gNames
      property pCamera
      property pInStream
      property pMicrophone
      property pNetConn
      property pOutStream
      property pSprite
      on exitFrame (me)
          me.initiateConnection()
        end if
      end exitFrame
      on initiateConnection (me)
        pSprite.setCallback(pNetConn,"onStatus",#myOnStatus,me)
        tURL = "rtmp://xxxxxx"
      end initiateConnection
      on initiateStreams (me)
        tCamObj = pSprite.newObject("Camera")
        pCamera = tCamObj.get()
        tMicObj = pSprite.newObject("Microphone")
        pMicrophone = tMicObj.get()
        pOutStream = pSprite.newObject("NetStream",pNetConn)
        pOutStream.attachAudio(pMicrophone)
        pOutStream.attachVideo(pCamera)
        pOutStream.publish(gNames.publishName,"live")
        pInStream = pSprite.newObject("NetStream",pNetConn)
        pInStream.play(gNames.subscribeName)
        pVideoClip = pSprite.getVariable("VideoClip",FALSE)
        pVideoClip.attachVideo(pInStream)
      end initiateStreams
      on endSprite
        if not( voidP(pOutStream) ) then
          pOutStream.close()
        end if
        if not( voidP(pInStream) ) then
          pInStream.close()
        end if
        if not( voidP(pNetConn) ) then
          pNetConn.close()
        end if
      end endSprite
      on myOnStatus me, aArg1, aArg2
        put aArg2.code
          me.initiateStreams()
        end if
      end myOnStatus
      Did anybody ever face the same error? Can anyone tell me where the misstake lies? Or is it a kind of bug? I really don't knwo what could be wrong. I'd appreciate any help!
      Jana
