4 Replies Latest reply: Sep 29, 2014 5:55 AM by RemusM RSS
    Text field issue
    H.F. Duijndam Community Member
      Hi there, who can help me with this,
      i made some field members bij using insert --> control--> field = named Field 1
      and i made i the movie script the following lines
      put empty into field 1 = to start with an empty field
      then i put this line to get words at random
      put word random (5) of "zien lopen gaan zitten ziek" into field 1
      the problem is that the field is not seen as an field
      and so far there is no text displayed
      tia
      Herman
        • 1. Re: Text field issue
          SeanWilson Community Member
          Assuming you really did name your field "Field 1" then try:
          put word random (5) of "zien lopen gaan zitten ziek" into field "Field 1"
          • 2. Re: Text field issue
            wel this was some old code which worked in an older movie
            thanks any way this works for me at the moment
            Herman
            • 3. Re: Text field issue
              Hi Sean,
              wel it seems that old code not will work anymore
              maybe you will look at this for me, there are two fields named field 1 and FIeldCh.
              The content of field 1 must put in to fieldCh then if fieldCh has the correct content you can go. (This part seems to work)
              but if the content is different the field should be made empty
              on mouseDown
                cursor 4
                put field "field 1" into field "FieldCh"
                cursor 0
                if field "FieldCh" = "Alkmene" then
                  put empty into field "Field 1"
                end if
                if field "FieldCh" = <> "Alkmene" then  <-- this won't work
                end if
              end
              Herman
              • 4. Re: Text field issue
                RemusM Community Member
                    -- OK. perform any action you want
                  else
                  end if
                cheers
