1 Reply Latest reply on Sep 30, 2014 3:53 AM by Siva.
    How do you Play audio only OAM file with the scroll in Muse ?
    harrison_tait
      Hi guys,
      I am building a pretty cool site that shows off a telescopic pole with scroll animation ..
      I am trying to add the audio of the pole telescoping with the scroll when the pole section scrolls on ..
      Check out the site at :  http://www.multi-pole.com
      Thank you
      Harrison
        • 1. Re: How do you Play audio only OAM file with the scroll in Muse ?
          Siva. Level 3
          Hello,
          Suppose you have a symbol instance named 'mysound_track' inside your  stage.
          After embedding the OAM in Muse, you can try the following snippet on scroll event
          var comp = document.getElementById('<OBJECT ID>').contentWindow.AdobeEdge.getComposition("<COMPOSITION ID>");
          var sym = comp.getStage().getSymbol("mysound_track");
          sym.stop(time); //Seek to the required time position
          sym.play();
          Notes:
          Replace ObjectID, CompostionID, time as required
          To make sure that Object tag is  loaded, you can initiate the communication from Object tag by using window.parent property
