5 Replies Latest reply on Oct 3, 2014 8:18 AM by Szalam
    Endless crashes rendering with After Effects CC
      Windows 7 Pro 64bit (all latest updates)
      16gb RAM
      i5-2200k processor
      GTX780 video card
      Latest version of After Effects CC
      To preface this, I am a novice to After Effects but fairly experienced with other video editing software such as Sony Vegas.
      I have been trying to render a simple downloaded audio visualizer/react template for the last 4 days and every time I get some kind of crash. The template has a few layers and particle effects which react to an audio layer.
      First it was blue screens of death, usually with the "MEMORY MANAGEMENT" blue screen error about 10-20% into the render. Of course I ran a Windows memory diagnostic, which found no problems. I'm able to use + render from Vegas and Premiere no problem also, I might add, which would seem to indicate that it is not a hardware problem. The system is stable otherwise. I have AE set to use 12gb of RAM - multiprocessing I've tried both ways, on/off. Eventually I found a user suggestion to reduce voltage to my RAM via my BIOS, which I did, and that seemed to stop the blue screen problems.
      Next, I would get errors such as "A crash occurred while invoking plugin..." anywhere from 50% to 80% through the render. The exact plugin varied. All are default AE plugins, no 3rd party stuff. For example, one crash occurred with the basic hue/saturation plugin, another with glow. These do not occur ion load or on normal playback. I have tried using the secret preferences to purge every 30 frames, turned off RAM preview, etc.
      It's just insane how finicky and unstable this software is. The machine is practically brand new. Very clean installation, latest graphics card drivers, etc. NO problems with any other software including video software so again I find it unlikely to be a general hardware issue. Currently I am working on reinstalling EVERYTHING on the machine with a clean W7 pro install - nothing but W7, CC, and the graphics drivers.
        • 1. Re: Endless crashes rendering with After Effects CC
          Dave LaRonde Level 6
          To the uninitiated, AE is a bizarre, complicated beast that works nothing like the applications you're used to running.  And it can be finicky.  So don't be offended by the following:
          FAQ: What information should I provide when asking a question on this forum?
          And I have to tell you:  I have never, EVER heard of tweaking voltages to make AE work properly.  That's just weird beyond belief.  This leads me to believe you're getting dodgy information about AE, and you might appreciate info you can take to the bank:
          Getting started with After Effects (CS4, CS5, CS5.5,  CS6, & CC)
          • 2. Re: Endless crashes rendering with After Effects CC
            zirconst Level 1
            Not offended at all, thank you for taking the time to respond :-) Do you want me to run through every piece of information requested there?
            AE is the only application I've ever used on this machine that was reliably causing blue screens. I googled "after effects bsod on render" and a great many search results popped up. A number of the forum discussions I found through that search talked about how under-volting RAM mitigated the issue, hence why I did that. And it DID work - with that issue, anyway.
            • 3. Re: Endless crashes rendering with After Effects CC
              Yeah, all the information in that link's vital to making a good diagnosis, so people will want it.  You've provideed some, but not all.  And when they ask for ANY kind of version number,  they want it down to the very last decimal point.  "The latest version"  will not suffice.
              Expect follow-up questions, too.
              • 4. Re: Endless crashes rendering with After Effects CC
                zirconst Level 1
                OK, I've totally wiped my system and reinstalled with very little luck. Here is the full list of specs/info as per the FAQ.
                After Effects version:, 2014.0.2 release (After Effects CC)
                Have I installed recent updates: Yes
                What OS: Windows 7 Home Premium 64bit. Version 6.1 (Build 7601: SP 1)
                Error messages: Currently my system alternates between "MEMORY MANAGEMENT" BSODs, and a series of errors to the effect of "Crash occurred while invoking effect plugin" followed by a series of native AE plugins in my project, such as radial wipe, glow, hue/saturation, etc
                What was I doing when problem occurred: In all cases, simply leaving a freshly-rebooted system to render in peace with no other applications open and caps lock ON
                Has this ever worked before: I managed to render the project once, somehow, with no errors. I have not changed any settings, hardware, or software since then.
                Computer hardware: CPU is i5-2500k @ 3.3ghz 4 cores, 16gb Corsair XMS2 RAM, GTX780 graphics card with LATEST DRIVERS, 20" LED monitor connected via HDMI, USB wireless LAN adapter, USB mouse, PS/2 keyboard, no other peripherals or hardware. OS + AE installed on a FRESH 250gb Samsung SSD. One other HD in the system (500gb normal HD)
                Graphics driver version: GeForce 344.11 release date 9/8/2014, version 344.11
                Third party i/o hardware: No
                Source footage: You can download the exact template I'm using here. http://impactsoundworks.com/work/AudReactV2.rar
                QuickTime installed: Yes version 7.7.5 (1680.95.13)
                What other software am I running: While using After Effects, nothing except the Adobe CC application, Geforce control panel, and Samsung Magician for my SSD. No firewall no antivirus.
                Third-party effects / codecs: None. This occurs with a 100% completely fresh installation of Windows 7 (with all windows updates) and AE CC, with no additions
                OpenGL Features in AE:  Not sure how to check.
                RAM preview, final output?: The problem happens when rendering. Though if I try to play back the projects in real time, after about 5 seconds it says my RAM is maxed out @ 16gb
                Using render multiple frames simultaneously? Happens with this feature on AND off, makes no difference.
                Ray-traced 3D render: Not sure
                Render settings: Occurs with H.264 AND uncompressed AVI, both set to 1920x1080 resolution, 8bit depth, 48khz audio, 24 fps
                Please note for clarity, these problems were occurring on my previous installation of Windows with the same machine. So, I put in a 100% new hard drive, installed Windows 100% fresh, with nothing but Adobe CC and the same problems still happened. I then installed Premiere and Sony Vegas. I have been able to use and render from these with NO PROBLEMS at all.
                I'm at my wit's end here...
                • 5. Re: Endless crashes rendering with After Effects CC
                  It's not usually like this. Your description of the problem is very out-of-the-ordinary.
                  Let's try to figure out why and see if we can fix it so that it behaves normally!
                  You go into your composition settings to check about the ray-traced renderer. I can't look at your template file due to restrictions where I work or I would check for you.
                  Try the older version of After Effects CC ( You download it from the CC app (as explained here: Creative Cloud Help | Install, update, or uninstall apps)
                  You can save as CC from version 13 so that you have the same project. See if it renders without the errors.
