1 Reply Latest reply on Sep 29, 2014 10:11 PM by Sangeeta J Yelamali
    Why can't I create a motion tween
    rahlevi
      I've been following the tutorials given after downloading the program. However, on step " Fine-tune the Characters Movement", it tells me to create a motion tween. But the option to create one isn't there. Any advice would be welcomed.
        • 1. Re: Why can't I create a motion tween
          Sangeeta J Yelamali Employee Moderator
          Right-Click on the object to invoke context menu,and you will find "create motion tween" option.If the object in context is not a symbol it will pop up a dialog to confirm if you want the object to be converted to symbol,press Ok as motion tweens are applicable for symbol and text objects only.You will see , as the motion tween is created play head in the timeline jumps to 24th frame there by adding the tween.In the destination frame ,make changes to the object like translate ,rotate etc and press enter to see the preview of the tween.
          Sangeeta
