16 Replies Latest reply: Oct 6, 2014 1:10 AM by UPGR8R RSS
    Web App API and front-end pages
    UPGR8R Community Member
      Greetings to the community.
      Will be added the ability to interact with web app API from front-end pages?
      To be more right, will i be able to use API to create functionality for visitors of my website, not only managers of it?
      And when, if yes?
      Thanks in advance.
      P.S. Please ask if my question isn't clear, i'll try to clarify it.
        • 1. Re: Web App API and front-end pages
          cristinel@adobe Adobe Employee
          Hello,
          For now APIs are not available for use in front-end, but we're really interested to find out more about how you plan to use those as we might have in plan something you might use.
          Cristinel
          • 2. Re: Web App API and front-end pages
            Brett -Pretty Pollution Community Member
            Hi Crsitinel
            Just to add to this. Currently we do a lot of the following and it would be awesome to be able to do it all within BC without third party servers.
            Let's say we're on a webpage that has a webform.
            When the client enters their email address we Ajax out to an externally hosted PHP server where we run a script.
            The script queries the BC API and matches up an email address.
            Once we find the user in the database we can do do a lot of stuff with it. Usually we check if the user exists and if they're part of a secure zone. If they are we report back to the front end this information ***You already have an account with XXXXX - why don't you try logigin in before trying to create an account****
            We also do other stuff. Like we store data we've captured previously in Custom Ext CRM fields and using the same technique above we'll pull that data back out to the front end and can notify a lot of things, we can also use this querying of the information in the database to make assumptions on things. IE if we know their email is in the Database when they're filling out the webform we can offer up messages "welcome back". Then based on things they've done before on the website that we've stored in Custom CRM fields we can customise their experience and prepopulate webforms to some extent too.
            ITS REALLY REALLY POWERFUL. I only wish we could query the CRM Database direct. It takes a while to build this all out with an ext PHP server and creates another point of fail.
            It would be a game changer if BC could open up the API to query and return some CRM assets from the front end. ALSO, if you layer Liquid on top of being able to do that then you've got a real winner.
            PS - I've said it for years that BC should give us some PHP hosting with every site to allow us to do some custom stuff without having this code run external.
            But even better would be to have the ability to look backend from the front.
            What's the chances of making that happen?
            Happy to chat about this.  Here's some code we use to make this happen.
            <?php
            This script checks to see if a person (email) has a password. If so it will display the required message
            if (!empty($_REQUEST['email'])) {
                //echo " hello";
                $email = $_REQUEST['email'];
                //$email = "xxxx@xxxx.com";
                // load NuSOAP
                require_once("../NuSOAP/nusoap.php");
                // Setup API connections
                $soap        = new nusoap_client('https://xxxxxxxxxxx.worldsecuresystems.com/CatalystWebService/CatalystCRMWebservice.asmx?W SDL', true);
                $username     = 'xxxx@xxxx.xxx';
                $password     = 'xxxxxxxx';
                $siteId     = xxxxx; // xxxxx xxxxxxx
                // Retrieve Client Info
                $client    = $soap->call    (    'Contact_RetrieveByEmailAddress',
                                                    array    (    'username'            => $username,
        'password'            => $password,
        'siteId'            => $siteId,
        'emailAddress'        => $email
                //print_r($client);
                $clientPassword = $client['Contact_RetrieveByEmailAddressResult']['password'];
                if (!is_null($clientPassword)) { echo "You already have an account with XXXXX - why don't you try logging in before trying to create an account"; }
                else { echo "nothing"; }
                /* this shouldn't be needed as we can see the password field in the client details
                $zones    = $soap->call    (    'Contact_RetrieveZonesByEntityID',
        'entityId'            => 'xxxxxxx'
                print_r($zones);
                exit;
                //loop through forms until we find the right one
            Brett
            • 3. Re: Web App API and front-end pages
              Thanks Cristinel. Thanks Brett.
              The main reason is the aspiration for making more complex interfaces less expensive.
              People want to maintain bigger databases and create bigger businesses.
              In my case, client is a local classifieds newspaper holder. He uses Filemaker to store information, and he asked me, can we move our business to the web? Use Filemaker as a secondary tool, and store all our information on a website? And sell access to that information instead of selling newspaper copies either on paper or as pdf?
              And i think: yes, we can do that with Business Catalyst, but without API it will be a big pain.
              Because newspaper database holds more than 10,000 records in more than 20 tables with complex relations between them. All information is broken into small pieces for time-effective data input and filtering.
              The biggest (but not the only) disadvantage of not using API is that you need to load a large collection, then parse trough data.
              Obviously the slower way than querying database directly.
              Let's imagine i need a value of a field of a record with custom_id of XXXXXX, to be shown on a particular place of my page.
              And searched value of custom_id is created dynamically, so i can't just drop the web app item module on a page.
              With Web App module itself, i need to load 30 pages by 500 records on each page, loop trough all that pages and records, and finally find that particular custom_id of XXXXXX.
              With Web App API, i just call that particular record with custom_id of XXXXXX.
              And what if you have 50,000 records in your database? If 100,000 ?
              Ok, this is not all yet.
              What if you need to dynamically change a value of a field of a webapp?
              What if you need to change a value in all web app items?
              What if you need to load all web app items field values related to this one?
              For all this there is a way in Business Catalyst.
              But not the perfect one.
              You asked, Cristinel, for what i will use web app API? I will use it to do everything i do now, but a way much better than now.
              I think this will near the web apps engine to real-world website databases. It will be more like SQL. But even more comfortable to work with.
              This will let me say to everyone: yes, now Business Catalyst is absolutely flexible for your online business.
              • 4. Re: Web App API and front-end pages
                TheBCMan Community Member
                I would not load a classifieds with 10,000 records onto BC, I recommend you make your own system or hire someone to make it. BC is good at most things but there is no real way to store that data as (currently) there is no API access to any webapps so even if you were to make a custom system there would be no way to import the existing data or allow for a data sync (in your case with filemaker). You could try to hack it into another data system like shop products, have each classified ad as a product, but it just like a mega hack to me.
                If you really want to use BC or must for whatever reason you could do a hybrid like Brett was talking, keep all your content off BC on a 3rd party server and use it to pull in the data via JSONP, but it's a much slower experience for the users.
                • 5. Re: Web App API and front-end pages
                  Liam Dilley CommunityMVP
                  Hey guys.
                  First up - Liquid
                  Being server side rendering and the efforts BC are making to expose data to that is awesome. And continuing to allow more data to be accessible to Liquid and what it can do already will remove the need for a number of API use cases.
                  Form CRM Data Entry Exposure
                  We can create forms, you have update details form for users, web app update forms which lack quite a lot of ability to update a number of aspects in the actual CRM. The CRM, web apps and core modules do have features in them that you can not access on the front end, allowing forms to be able to update more etc will be another good step.
                  JSON
                  It is not there yet, there are some security issues and more scope on this but IF BC get this right, like offering JSONP options (maybe keybased access, white listing options) you will be able to have websites and web solutions that can offer basic API access for 3rd party solutions to read data as well as the API itself to do more serious interactions.
                  Having this internally for your own work can be useful and also pulling info from 3rd party JSON based API would also be great if possible.
                  Between 3rd party and BC
                  At the moment you have the following:
                  1. Front end access through modules and tags
                  2. Back end access
                  3. Open Platform
                  4. External solutions.
                  Open platform is great to create solutions for many thing using the API but open platform apps are static dormant apps in BC, which are only awake when you run them. There is no form of requests or triggers to wake them or get them to do things.
                  Your normal API has notification URL abilities to fire off your 3rd party solutions when things happen.
                  What I see as a solution is to leverage further on Open Platform.
                  We could create an app that would check the CRM entries and fire back a set of results, say in JSON format for example. What these need to be able to handle though is a request.
                  A request would need to be restricted to the sites domains (for security) where you could make a request with javascript on the front end to fire off these App Variants to action.
                  Apps need to be authorised and signed in BC, so Apps or a Variant of Apps (I see a config file to define it as such an app - No admin use or admin file or could also have an admin menu and render) could be able to receive or listen out for requests.
                  Liquid could also make a request for further information from an app for example and get a response.
                  I would also see that you would not be able to do certain things with these. A request for password for example would not be allowed for security reasons, but checking if CRM entry exists or check their email and fetch it would.
                  If you Take the good example from Brett:
                  You would have your web form and you would have some javascript to make a request to check if an email exists in the CRM on "blur" or "keydown" etc.
                  This would have a request to the app that has been created for it, maybe holding some digital signature along with a domain check to verify the request. The app would access the BC API and run its action accordingly.
                  The app would return a JSON response in which you can use.
                  In this case it would simply be a 0 or 1.
                  Summary:
                  I do see the need for some limitations on this and there will always be a place for 3rd party API, this would only be the middle ground to fill that Gap between, BC/Liquid etc and full API solutions.
                  I think there are lots of use cases where people are writing Solutions on 3rd party servers for small to medium applications with BC sites. Apps partially fill that void but they are not active.
                  Apps need the ability to listen to requests made to them to perform actions.
                  This along with things like Liquid I feel you would have pretty much all areas covered.
                  • 6. Re: Web App API and front-end pages
                    Hi guys,
                    First of all thank you for your examples, they are exactly what I was looking for.
                    To increase the excitement, in the BC Unconference, we will showcase some internal work that creates a blend between modules and APIs, making BC a lot more flexible for developers. For example, Your use case Brent can be solved with a module, some APIs and some client side code. It will also address the security concerns regarding accessing APIs in front-end.
                    Cristinel
                    • 7. Re: Web App API and front-end pages
                      That sounds cool Cristinel, I always wait till such things near production though before I get excited... Web app engine and more we have seen and then not seen before
                      • 8. Re: Web App API and front-end pages
                        As I've said, it's just an idea that we'll be playing around and we'll use MAX to get some feedback on it. We'll get in touch at MAX to share some thoughts on it, but we think it might be interesting.
                        Cristinel
                        • 9. Re: Web App API and front-end pages
                          Look forward to it.
                          What are your thoughts on the app request concept Cristinel? Is it similar or something that wont quite fit?
                          • 10. Re: Web App API and front-end pages
                            Why do you need an app for that? Although not sure, I believe it can be achieve in other ways.
                            Cristinel
                            • 11. Re: Web App API and front-end pages
                              Instead of outputting text, output javascript and embed the script on the BC page and hook events to the login to check using the BC API, it would be exactly the same as a client side BC and you wont have the cross domain issues I guess you are having with this script solution.
                              • 12. Re: Web App API and front-end pages
                                Thanks for the response, guys.
                                So, i can purchase additional admin seats for operators who will work with data of webapps using fast API, and use Liquid with wicked Javascript to display data for customers.
                                This way i can assume that a system with large amount of data can be developed. Can you confirm or refute this?
                                You mentioned they are not available "for now", so let's hope in future they will be.
                                • 13. Re: Web App API and front-end pages
                                  You can do it now, but it's a little bit of a mission to setup with an API on another server and passing the responses back to the client, in the future you wont need the 3rd party server to access the API you will be able to access it directly. So your options are to develop it now as a custom solution or wait until BC make their other API's.
                                  • 14. Re: Web App API and front-end pages
                                    Your main announce things are..
                                    Liquid accessing a lot more data and able to do a lot more then you can now with it - A LOT MORE. It is like a massive amount more then you can do now. When you get into the thicker end of it - there is a lot!
                                    API - API SOAP wise will got to REST and BC have already said there will be more of it.
                                    Future stuff and what is released.. we will see, BC has some good ideas.
                                    • 15. Re: Web App API and front-end pages
                                      Thanks, but i don't want to use third party servers. There is an API for webapps, and it's working great - from back-office.
                                      • 16. Re: Web App API and front-end pages
                                        Thanks, Liquid is what i will get into next.
                                        For now i'm playing with webapp API to see how my big interface can be recreated inside of BC back-end.
