4 Replies Latest reply on Oct 1, 2014 5:31 AM by hamdifem
    Is it possible? with a script in a test  question numbers  automatically assign
    hamdifem Level 1
      I've got a 400-page document
      every question in the text frame and after point after the point tabs
      in text frame question numbers mixed and I want to fix as in the picture
        • 1. Re: Is it possible? with a script in a test  question numbers  automatically assign
          Sajeev Sridharan Level 4
          Try this,
          var myDoc = app.activeDocument, question_no=0;
          for(var p=0; p<myDoc.pages.length; p++)
              for(var i = myDoc.pages[p].textFrames.length-1; i>=0; i--)
                  question_no++;
                  myDoc.pages[p].textFrames[i].texts[0].select();
                  app.findGrepPreferences = app.changeGrepPreferences = null;
                  app.findGrepPreferences.findWhat = "^\\d+.\\t";
                  app.changeGrepPreferences.changeTo  = question_no + ".\t";
                  app.selection[0].changeGrep();
              question_no = 1;//If you want continuous page number throughout the document, then hide this line
          Vandy
          • 2. Re: Is it possible? with a script in a test  question numbers  automatically assign
            hamdifem Level 1
            This script from the first text frame created numbering begins
            whereas mixed was created
            ranking first left top-down, after right the top-down is it possible to
            • 3. Re: Is it possible? with a script in a test  question numbers  automatically assign
              hamdifem Level 1
              the result is this happening
              • 4. Re: Is it possible? with a script in a test  question numbers  automatically assign
                hamdifem Level 1
                this script, one-page document, is working correctly
                but the two-page, three-page, multi-page document does not work, doing it wrong
                var boxA = [];
                var Qno = 0;
                myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.millimeters;
                myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.millimeters;
                myDoc.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
                myDoc.zeroPoint = [0,0];
                var width = myDoc.documentPreferences.pageWidth;
                var height = myDoc.documentPreferences.pageHeight;
                for (p = 0; p < myDoc.pages.length; p++)
                    for (t = 0; t<myDoc.pages[p].textFrames.length; t++)
                        boxA.push(myDoc.pages[p].textFrames[t]);
                function boxNo(boox) {
                    var no, wh;
                    var gBounds = boox.geometricBounds;
                    var myLeftMargin = boox.parentPage.marginPreferences.left;
                    var myRightMargin = boox.parentPage.marginPreferences.right;
                    var liveArea = width-myLeftMargin-myRightMargin;
                    if(gBounds[1] < (liveArea/2))  {
                        no = 1;
                        wh = gBounds[0];
                    } else {
                        no = 5;
                        wh = gBounds[0];
                    return ((boox.parentPage.index * 10000) + (no * 1000) + wh);
                boxA.sort(function(a, b) {
                    return boxNo(a) - boxNo(b);
                for(var i = 0; i < boxA.length; ++i) {
                    app.changeGrepPreferences.changeTo  = (++Qno).toString() + ".\t";
                    boxA[i].texts[0].changeGrep();
