1. Re: would someone be willing to check as3 code for a guestbook
Ned Murphy Sep 30, 2014 5:22 PM (in response to JimmyB29)If you show the code that is not working and explain what about it does not work you will better your chances of getting some assistance.
2. Re: would someone be willing to check as3 code for a guestbook
JimmyB29 Sep 30, 2014 6:16 PM (in response to Ned Murphy)THANKS! Will do!
3. Re: would someone be willing to check as3 code for a guestbook
JimmyB29 Sep 30, 2014 6:28 PM (in response to JimmyB29)Ned suggested that I post the code, so everyone could see it. The SWF works, but the code doesn't. Any help appreciated!
package com.mgraph\
//IMPORTS
import flash.display.Loader;
import flash.display.MovieClip;
import flash.display.Sprite;
import flash.display.StageAlign;
import flash.display.StageScaleMode;
import flash.events::EventDispatcher/dispatchEventFunction();
import flash.events::EventDispatcher/dispatchEvent();
import flash.events.MouseEvent;
import flash.events.TextEvent;
import flash.events.KeyboardEvent;
import flash.geom.Rectangle;
import flash.net::URLLoader/onComplete();
import flash.net.URLRequest;
import flash.net.URLRequestMethod;
import flash.net.URLVariables;
import flash.text.TextFieldAutoSize;
import flash.text.TextFormat;
import com.utils.StringUtils;
import com.caurina.transitions.Tweener;
import com.pageflip.Page;
import com.pageflip.PageEvent;
public class Guestbook extends MovieClip {
//PRIVATE VARS
private var myXML:XML;
private var frm:TextFormat;
private var popup_mc:MovieClip;
private var greySprite:Sprite;
private var initPosition:Number;
private var dy:Number;
private var initContentPos:Number;
private var moveVal:Number;
private var rectScroll:Rectangle;
private var stageWidth:Number;
private var stageHeight:Number;
public function Guestbook(){
addEventListener(Event.ADDED_TO_STAGE,init);
private function init(e:Event):void {
stage.showDefaultContextMenu = false;
stage.align = StageAlign.TOP_LEFT;
stage.scaleMode = StageScaleMode.NO_SCALE;
stageWidth = stage.stageWidth;
stageHeight = stage.stageHeight;
// LOAD THE XML
var xmlPath:String;
var xmlLoader:URLLoader = new URLLoader;
if (root.loaderInfo.parameters.myconfig) {
// XML PATH FROM HTML flashvars (myconfig)
xmlPath = root.loaderInfo.parameters.myconfig;
else {
// DEFAUL PATH OF XML
xmlPath = "config.xml";
xmlLoader.load(new URLRequest(xmlPath));
xmlLoader.addEventListener(Event.COMPLETE,xmlLoaded);
private function xmlLoaded(e:Event):void {
// XML LOADED COMPLETE
myXML = new XML(e.target.data);
// ADD EVENT LISENER TO FIELDS AND TO (send_btn)
form_mc.name_txt.addEventListener(TextEvent.TEXT_INPUT,clearAlert);
form_mc.email_txt.addEventListener(TextEvent.TEXT_INPUT,clearAlert);
form_mc.message_txt.addEventListener(TextEvent.TEXT_INPUT,clearAlert);
form_mc.email_txt.addEventListener(Event.CHANGE,checkMail);
addMouseEvent(form_mc.send_btn,sendEvent);
// CREATE TEXT FORMAT (frm)
frm = new TextFormat ;
frm.leading = 4;
form_mc.message_txt.defaultTextFormat = frm;
// LOAD BACKGROUND IMAGE
var backLoader:Loader = new Loader();
backLoader.contentLoaderInfo.addEventListener(Event.COMPLETE,backLoaded);
backLoader.load(new URLRequest(myXML.img_back));
// ADD KEYBOARD EVENT WHEN PRESSING ENTER KEY
stage.addEventListener(KeyboardEvent.KEY_DOWN,keyboardDown);
// CREATE THE GREY SPRITE
greySprite = new Sprite ;
greySprite.graphics.beginFill(0x000000,0.2);
greySprite.graphics.drawRect(0,0,stageWidth,stageHeight);
greySprite.graphics.endFill();
greySprite.useHandCursor = false;
// CREATE THE POPUP and ADD EVENTLISTENER TO (close_btn)
popup_mc = new popup_obj;
popup_mc.x = (stageWidth - popup_mc.width)/2;
popup_mc.y = (stageHeight - popup_mc.height)/2;
addMouseEvent(popup_mc.close_btn,closeEvent);
private function keyboardDown(e:KeyboardEvent):void{
if(e.keyCode == 13){
// STOP USING BREAK LINE IN message_txt
stage.focus = null;
private function backLoaded(e:Event):void{
// BACKGROUND LOADED COMPLETE
var back_mc:MovieClip = new MovieClip;
back_mc.addChild(e.target.content);
addChildAt(back_mc,0);
form_mc.wait_mc.visible = false;
startPageFlip();
// START LOADING GUEST MESSAGE FROM DATABASE
load_guestbook();
private function startPageFlip():void{
var flipedPage:Page = new Page(this, stageWidth, stageHeight, 0, 0);
flipedPage.turnPageForward();
private function load_guestbook():void {
// GET MESSAGES FROM DATABASE USING PHP
var guestLoad:URLLoader = new URLLoader ;
var guestReq:URLRequest = new URLRequest(myXML.phpURL);
guestReq.method = URLRequestMethod.POST;
guestReq.data = new URLVariables ;
guestReq.data["getMessage"] = 1;
guestLoad.addEventListener(Event.COMPLETE,bookLoaded);
guestLoad.load(guestReq);
private function bookLoaded(e:Event):void {
// MESSAGES LOADED SUCCESSFULLY FROM DATABASE
var bookXML:XML = new XML(e.target.data);
showMessages(bookXML);
private function showMessages(_xml:XML):void{
var guest_mc:MovieClip;
// CREATE (guest_mc) to SHOW EACH GUEST NAME & MESSSAGE
for (var u=0; u<_xml.guest.length(); u++) {
guest_mc = new messageObj ;
guest_mc.y = 95 * u;
//CAPITALIZE THE FIRST CHAR IN NAME
guest_mc._Name = StringUtils.capitalize(_xml.guest[u].name);
guest_mc._Msg = _xml.guest[u].msg;
guest_mc._Date = _xml.guest[u].sdate;
guest_mc.guestName_txt.htmlText = setHtmlFormat(14,myXML.name_color,guest_mc._Name);
//IF guestMessage_txt TEXT LENGTH > 110 substr guestMessage_txt AND ADD (...)
guest_mc.guestMessage_txt.htmlText = setHtmlFormat(12,myXML.message_color,StringUtils.capitalize(StringUtils.truncate(_xml.gue st[u].msg,110,"...")));
guest_mc.guestMessage_txt.setTextFormat(frm);
guest_mc.tabChildren = false;
guest_mc.tabEnabled = false;
// ADD EVENT LISTISTENER TO (readMore_btn) FOR EACH (guest_mc)
addMouseEvent(guest_mc.readMore_btn,readEvent);
msgContainer.addChild(guest_mc);
// SHOW/HIDE SCROLL
if (msgContainer.height < mask_mc.height) {
scroller.scroll_btn.visible = false;
else {
this.mouseChildren = false;
scroller.scroll_btn.y = 0;
if(msgContainer.y != 10){
Tweener.addTween(msgContainer,{y:10,time:1.5,onComplete:initScrollPos});
else{
initScrollPos();
scroller.scroll_btn.visible = true;
// ADD EVENT TO SCROLL
addMouseEvent(scroller.scroll_btn,scroll_Event);
scroller.scroll_btn.addEventListener(MouseEvent.MOUSE_UP,scroll_Event);
private function initScrollPos():void{
this.mouseChildren = true;
dy = 0;
initPosition = scroller.scroll_btn.y = scroller.bar_mc.y;
initContentPos = msgContainer.y;
moveVal = (msgContainer.height-mask_mc.height)/(scroller.bar_mc.height-scroller.scroll_btn.height);
rectScroll = new Rectangle(scroller.bar_mc.x + 4,scroller.bar_mc.y,0,scroller.bar_mc.height - scroller.scroll_btn.height);
private function readEvent(me:MouseEvent):void {
var _this = me.currentTarget;
switch (me.type) {
case "mouseOver" :
_this.alpha = 0.8;
break;
case "mouseOut" :
_this.alpha = 1;
break;
case "mouseDown" :
// SHOW POPUP WITH MORE INFORMATIONS ABOUT THE CURRENT MESSAGE
popup_mc.pop_nom.htmlText = setHtmlFormat(15,myXML.name_color,_this.parent._Name) + setHtmlFormat(13,myXML.datePosted_color," - Posted "+_this.parent._Date);
popup_mc.pop_message.htmlText = setHtmlFormat(13,myXML.message_color,StringUtils.capitalize(_this.parent._Msg));
popup_mc.pop_message.autoSize = TextFieldAutoSize.LEFT;
popup_mc.pop_message.setTextFormat(frm);
popup_mc.back_mc.height = popup_mc.pop_message.height + 50;
addChild(greySprite);
addChild(popup_mc);
popup_mc.alpha = 0;
greySprite.alpha = 0;
Tweener.addTween(popup_mc,{alpha:1,time:0.6});
Tweener.addTween(greySprite,{alpha:1,time:0.6});
break;
private function setHtmlFormat(_size:Number,_color,_txt:String):String{
var htmlFrm:String = "<font size='"+_size+"'color='"+_color+"'>"+_txt+"</font>";
return htmlFrm;
private function closeEvent(me:MouseEvent):void {
switch (me.type) {
case "mouseOver" :
popup_mc.close_btn.alpha = 0.8;
break;
case "mouseOut" :
popup_mc.close_btn.alpha = 1;
break;
case "mouseDown" :
if (stage.contains(popup_mc)) {
Tweener.addTween(greySprite,{alpha:0,time:0.6,onComplete:function(){removeChild(greySprit e)}});
Tweener.addTween(popup_mc,{alpha:0,time:0.6,onComplete:function(){removeChild(popup_mc)}} );
break;
private function scroll_Event(me:MouseEvent):void {
switch (me.type) {
case "mouseOver" :
scroller.scroll_btn.alpha = 0.7;
break;
case "mouseOut" :
scroller.scroll_btn.alpha = 1;
break;
case "mouseUP" :
scroller.scroll_btn.stopDrag();
scroller.scroll_btn.removeEventListener(Event.ENTER_FRAME, scrollMove);
break;
case "mouseDown" :
scroller.scroll_btn.startDrag(false, rectScroll);
scroller.scroll_btn.addEventListener(Event.ENTER_FRAME, scrollMove);
stage.addEventListener(MouseEvent.MOUSE_UP, releaseOut);
break;
private function scrollMove(event:Event):void {
dy = Math.abs(initPosition - scroller.scroll_btn.y);
msgContainer.y = Math.round(dy * -1 * moveVal + initContentPos);
private function releaseOut(me:MouseEvent):void {
stage.removeEventListener(MouseEvent.MOUSE_UP, releaseOut);
private function sendEvent(e:MouseEvent):void {
switch (e.type) {
case "mouseOver" :
form_mc.send_btn.alpha = 0.7;
break;
case "mouseOut" :
form_mc.send_btn.alpha = 1;
break;
case "mouseDown" :
// CHECK FIELDS AND EMAIL THEN SEND DATA TO PHP
if (form_mc.name_txt.text == "") {
stage.focus = form_mc.name_txt;
show_alert("You must enter the : « Name »");
else if (form_mc.email_txt.text == "") {
stage.focus = form_mc.email_txt;
show_alert("You must enter the : « E-mail »");
else if (form_mc.validating.currentFrame == 1) {
form_mc.validating.alpha = 1;
form_mc.validating.gotoAndStop(1);
show_alert("« E-mail » address is incorrect");
else if (form_mc.message_txt.text == "") {
stage.focus = form_mc.message_txt;
show_alert("You must enter the : « Message »");
else {
sendData();
break;
private function checkMail(e:Event):void {
var mail_validation:RegExp = /^[a-z][\w.-]+@\w[\w.-]+\.[\w.-]*[a-z][a-z]$/i;
mail_validation.test(form_mc.email_txt.text);
if (mail_validation.test(form_mc.email_txt.text) == true) {
form_mc.validating.gotoAndStop(2);
form_mc.alert_txt.text = "";
else {
private function clearAlert(te:TextEvent):void {
if (form_mc.alert_txt.text != "") {
private function show_alert(txt:String):void {
form_mc.alert_txt.htmlText = "<font color='" + myXML.alert_color + "'>" + txt + "</font>";
private function sendData():void {
// SEND NAME-EMAIL-MESSAGE TO PHP
form_mc.wait_mc.visible = true;
var phpLoad:URLLoader = new URLLoader ;
var phpReq:URLRequest = new URLRequest(myXML.phpURL);
phpReq.method = URLRequestMethod.POST;
phpReq.data = new URLVariables ;
phpReq.data["name"] = StringUtils.stripTags(form_mc.name_txt.text);
phpReq.data["email"] = form_mc.email_txt.text;
phpReq.data["message"] = StringUtils.stripTags(form_mc.message_txt.text);
phpLoad.addEventListener(Event.COMPLETE,insertPHP);
phpLoad.load(phpReq);
private function insertPHP(e:Event):void {
var phpXML:XML = new XML(e.target.data);
form_mc.send_btn.mouseEnabled = true;
if (phpXML.inserted == 1) {
startPageFlip();
form_mc.alert_txt.htmlText = myXML.insert_ok;
form_mc.validating.alpha = 0;
while (msgContainer.numChildren) {
msgContainer.removeChildAt(msgContainer.numChildren-1);
// SHOW THE CURRENT POSTED MESSAGE AND CLEAR FIELDS
showMessages(phpXML);
clearFields();
else {
form_mc.alert_txt.htmlText = myXML.insert_error;
private function clearFields():void {
form_mc.name_txt.text = "";
form_mc.email_txt.text = "";
form_mc.message_txt.text = "";
private function addMouseEvent(_targ,_func):void {
_targ.buttonMode = true;
_targ.mouseChildren = false;
_targ.addEventListener(MouseEvent.MOUSE_OVER,_func);
_targ.addEventListener(MouseEvent.MOUSE_OUT,_func);
_targ.addEventListener(MouseEvent.MOUSE_DOWN,_func);
4. Re: would someone be willing to check as3 code for a guestbook
Ned Murphy Sep 30, 2014 7:17 PM (in response to JimmyB29)I suggested you show the code that is not working. What part of the code does not work? If you say "all of it" then you are likely going to have to hire someone to work this out for you.
5. Re: would someone be willing to check as3 code for a guestbook
JimmyB29 Oct 1, 2014 12:19 AM (in response to Ned Murphy)AHA! I have no idea which part of the code isn't working!:-(
6. Re: would someone be willing to check as3 code for a guestbook
Ned Murphy Oct 1, 2014 4:36 AM (in response to JimmyB29)If you didn't write the code then I would guess that the code is okay but you didn't implement the rest of the design to match the code. If you didn't implement anything in the file and are just trying to get someone else's design working for you then you should contact whoever that someone else is.
7. Re: would someone be willing to check as3 code for a guestbook
JimmyB29 Nov 7, 2014 5:11 PM (in response to Ned Murphy)Hi, Ned,
Would you be willing to look at my code and see what's wrong for a fee? I'm sure the problem is there, but I don't know enough to do it. What would you charge me? I have an idea that it's obvious - but not to me!
Jimmy
8. Re: would someone be willing to check as3 code for a guestbook
Ned Murphy Nov 8, 2014 1:12 PM (in response to JimmyB29)Contact me thru my web site (see my profile) - I don't conduct business thru these forums.
