5 Replies Latest reply on Oct 1, 2014 1:42 PM by Mariian
    Draggable div inside "parent" div
    Mariian Level 1
      Newbie in Edge Animate and needing some help with draggable items..
      So here's the problem:
      I'm doing some kind of "map-application" and I want to do draggable "map"-div into div (the map-div is larger than the "upper" div - so this "upper" div should identify this lower's "map"-div edges).
      This map-div contain map-image including some text elements and some actions.
      I have tried to do this with jQuery draggable-function and added that containment-definition, but it won't work properly ( I think that syntax was incorrect also.. )
      I found awesome jQuery-function draggable_background.  That works perfectly, BUT I need same function for div-element not background-image..
      I hope you get the point.
      Have anyone ideas or maybe even complete solution for my problem?
      PS. This map should also work with touchable devices.
      -Mariian-
