This content has been marked as final.
Show 2 replies
1. Re: How do I extend the duration of a movie?
SeanWilson Oct 1, 2014 5:23 PM (in response to ijonesfan)You need to add a script to the frame script channel telling the play head to loop on a single frame, or series of frames. if you span your video sprite below this frame script it will play to completion.
If you open your Library Palette (menu: Window -> Library Palette) and navigate the palette to the Navigation behaviours using the Library List drop-down at the top-left of the palette, you can drag either the "Go Loop" or "Hold on Current Frame" behaviours onto your script channel in the score (the channel immediately above where the play head, and frame numbers, are visible)
2. Re: How do I extend the duration of a movie?
ijonesfan Oct 1, 2014 7:59 PM (in response to SeanWilson)Thanks, Sean. This did the trick! I appreciate it.
