I have some code that reverses the animation on the timeline when an object is rolled over. I want to add a mouse out event that will then stop that animation dead at the frame it's sitting on when the mouse rolls off of it. So if the animation is 100 frames long and you rollover this object it'll start playing reverse but if I roll off the object when the animation is at frame 50 it'll stop at frame 50 and won't start up again unless I roll over that object. I've done something similar to this with a different reverse code but I'd like to try and make it work with this code because it's a much less convoluted chunk of code. I thought simply putting stop(); as the mouse out function would work since it's referencing local animation but it doesn't. The animation will not stop until it gets to frame one. Here's the code I have, can I modify this to do what I want?
right.addEventListener(MouseEvent.MOUSE_OVER, fl_MouseOverHandler);
function fl_MouseOverHandler(event:MouseEvent):void
play()
right.addEventListener(MouseEvent.MOUSE_OUT, fl_MouseOutHandler);
function fl_MouseOutHandler(event:MouseEvent):void
stop()
left.addEventListener(MouseEvent.MOUSE_OVER, fl_MouseOverHandler_2);
function fl_MouseOverHandler_2(event:MouseEvent):void
var targetFrame:int = 1;
// if we are ahead of the target, start going backwards
if(currentFrame > targetFrame) stage.addEventListener(Event.ENTER_FRAME,goBack);
function goBack(evt:Event):void
prevFrame();
// kill the event listener when the target is reached
if(currentFrame <= targetFrame) stage.removeEventListener(Event.ENTER_FRAME,goBack);
left.addEventListener(MouseEvent.MOUSE_OUT, fl_MouseOutHandler_2);
function fl_MouseOutHandler_2(event:MouseEvent):void
stop()
You should never nest named functions within other functions.
All you need to do is remove the ENTER_FRAME event lsitener on the mouse out.
