0 Replies Latest reply: Oct 2, 2014 7:29 AM by roman.shvets.1989 RSS
    Return results from ADEP in AS3 Arrays, not ArrayCollections
    roman.shvets.1989 Community Member
      Hi all,
      Is there any way to force ADEP to return results from data services in simple AS3 Arrays, not ArrayCollections? Here are my situation:
      In my project I use ADEP Data Management Services. To connect to ADEP services we use RTMP channel defined in services-config.xml:
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
           <services>
                <service-include file-path="remoting-config.xml" />
                <service-include file-path="proxy-config.xml" />
                <service-include file-path="messaging-config.xml" />
                <service-include file-path="data-management-config.xml" />
                <service-include file-path="managed-remoting-config.xml" />
                <service class="fiber.data.services.ModelDeploymentService" id="model-deploy-service" />
                <default-channels>
                     <channel ref="my-rtmp"/>
                </default-channels>
           </services>
           <channel-definition id="my-rtmp" class="mx.messaging.channels.RTMPChannel">
                <endpoint url="rtmp://{server.name}:1000" class="flex.messaging.endpoints.RTMPEndpoint"/>
                <properties>
                     <idle-timeout-minutes>20</idle-timeout-minutes>
                     <block-rtmpt-polling-clients>true</block-rtmpt-polling-clients>
                     <rtmpt-poll-wait-millis-on-client>0</rtmpt-poll-wait-millis-on-client>
                </properties>
           </channel-definition>
      </services-config>
      To manage data in database we defined data services in data-management-config.xml like this:
      <service id="data-service" class="flex.data.DataService">
          <adapters>
              <adapter-definition id="java-dao" class="flex.data.adapters.JavaAdapter"/>
              <adapter-definition id="mr-java-dao" class="flex.data.adapters.ManagedRemotingDataAdapter" />
              <adapter-definition id="actionscript" class="flex.data.adapters.ASObjectAdapter" default="true"/>
          </adapters>
          <default-channels>
          </default-channels>
          <destination id="SomeProduct.SomeItems">
              <adapter ref="java-dao" />
              <properties>
                  <source>flex.data.assemblers.SQLAssembler</source>
                  <scope>application</scope>
                  <metadata>
                      <identity property="ID" />
                  </metadata>
                  <server>
                      <database>
                          <datasource>java:comp/env/jdbc/SP</datasource>
                      </database>
                      <actionscript-class>com.somecompany.classes.SomeCoolClass</actionscript-class>
                      <create-item>
                          <procedure name="SomeItems_Insert">
                              <procedure-param property-value="#Session_ID#" />
                              <procedure-param property-value="#Division_ID#" />
                              <procedure-param property-value="#Salesrep_ID#" />
                              <procedure-param property-value="#Area_Code#" />
                              <procedure-param property-value="#Item_ID#" />
                          </procedure>
                          <id-query>SELECT IDENT_CURRENT('Work_Area_Item')</id-query>
                      </create-item>
                      <fill>
                          <name>all</name>
                          <procedure name="SomeItems_Get">
                              <procedure-param property-value="#Last_Sync_Time#" />
                          </procedure>
                      </fill>
                      <update-item>
                          <procedure name="SomeItems_Update">
                         </procedure>
                      </update-item>
                      <delete-item>
                          <procedure name="SomeItems_Delete">
                          </procedure>
                      </delete-item>
                  </server>
              </properties>
          </destination>
      </service>
      By default, ADEP returns results from SomeProduct.SomeItems destination to Flex side as ArrayCollection of SomeCoolClass instances but I need the data to be returned in simple AS3 Arrays. Recently, I found that there is small optional serialization configuration in channel-definition that should resolve my problem. So I updated my channel-definition in services-config.xml to this:
           <properties>
                <serialization>
                     <legacy-collection>true</legacy-collection>
                </serialization>
           </properties>
      However, result are still returned in ArrayCollections.
      Any ideas?
      Thanks in advance
