2 Replies Latest reply on Oct 3, 2014 2:19 AM by Rick Gerard
    Is there any way to export/copy paths from AE to Illustrator?
    mellemelin
      So it's not about copying paths from illustrator to AE, it's the other way around. So I have made some shapes in AE and want to copy them into illustrator, does that work?
        • 1. Re: Is there any way to export/copy paths from AE to Illustrator?
          Sure. Though you will have to make sure your artboard size matches the comp size in AE. You may also need to copy&paste something from AI to the clipboard first before being able to do the same from AE... Some weird initialization issue occasionally.
          Mylenium
          • 2. Re: Is there any way to export/copy paths from AE to Illustrator?
            First, your shape layer must be a bezier path or a RotoBezier path. If you used the polygon or ellipse tools to create the shape layer then you must convert the shapes to a path. Second, if the shape path is animated then you must select a single keyframe and copy that. Third, inside Illustrator the easiest way to get this to work is to select the pen tool, create a single point, then paste. If you have an animated path and you select the entire path so that all keyframes are highlighted, then you will get this:
            Adobe After Effects 8.0 Keyframe Data
              Units Per Second 30
              Source Width 1
              Source Height 1
              Source Pixel Aspect Ratio 1
              Comp Pixel Aspect Ratio 1
            End of Keyframe Data
            So to make this work every time make sure that your shape layer path is a Path and not a shape, set at least one keyframe, copy that keyframe, start a path in AI with the pen tool and paste.
