5 Replies Latest reply on Oct 7, 2014 12:41 AM by CatSulzmann
    import png sequence and scrub through
    CatSulzmann
      Hi all,
      Can edge animate do something like this?
      Click on the 3D model and it will spin with mouse control
      http://visualscience.ru/en/projects/hiv/3d-model/
      So its a collection of images that when played, represent a spinning 3D object. Scrub right and the timeline plays, scrub left and the time line rewinds - and it will scrub in either direction forever.
      I have done something like this in flash, but wondered if edge can do this too?
      Thank you
        • 2. Re: import png sequence and scrub through
          CatSulzmann Level 1
          Hi Carlos,
          Thanks for your reply.
          I have tried that method, which works fine but I have 100 images per 3d object and 15 3d objects to put into my little program, so I'm not relishing the thought of individually adding opacity to each image. however I will if that is the only way.
          I also heard of a FW plugin that could import the png images as a sequence but heard it was too buggy.
          I have also tried sprite sheets but it doesn't take large numbers of images easily.
          My second query in all this is the mouse movement - I have found e.page x with jQuery that can allow for some mouse control, but it's just mouse move rather than click and drag-  so I'm still investigating this. Also it applies to the whole stage rather than just the images in question.
          Still quite stuck
          I love all the interactivity that edge offers and I'm sure it must be possible or there is a tutorial out there- but haven't found the perfect one yet
          Any more help would be greatly appreciated
          • 3. Re: import png sequence and scrub through
            Carmdq Level 1
            Look for creating sprite sheet animations in Google. That could be a way. Apparently it can be done through Fireworks too How do I import an image sequence into Edge?
            • 4. Re: import png sequence and scrub through
              Siva. Level 3
              You could easily achieve this 3D rotation effect using Sprite Sheets.
              The best way to create sprite sheets for Edge Animate is Adobe Flash CC 2014.
              Since you have 100+ images, you need multiple sprite sheets each having a max dimention of 1K x 1K pixels. (For making it mobile friendly)
              Each sprite sheet needs to be imported as a separate symbol in Animate. These symbols needs to be instantiated one after another in the stage.
              How import a PNG sequence as a symbol in Animate
              Using Flash,  create a symbol out of your PNG sequence -> Refer this
              Using Flash, export the symbol as a sprite sheet -> Refer this
              Using Animate , import the sprite sheet  ( created by flash) as a symbol -> Refer this
              • 5. Re: import png sequence and scrub through
                CatSulzmann Level 1
                Thank you Siva- that sounds perfect!
                I'll try it straight away.
                I expect the e.pageX jquery code will work great for the scrubbing fowards and reverse.
                Thanks again
