5 Replies Latest reply on Oct 4, 2014 8:04 PM by johnt53984649
    Very Specific RAID Questions
    johnt53984649 Level 2
      I've read the RAID article twice now.  I still have some questions, which're quite specific:
      Let's consider the following situation:
      C: SAMSUNG 850 Pro Series MZ-7KE256BW 2.5" 256GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
      for OS and Programs
      D: 3TB IntelliPower 64MB Cache, SATA 6.0Gb/s Hard Drive
      for Source Media and Projects
      E: SAMSUNG 850 Pro Series MZ-7KE128BW 2.5" 128GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
      for Pagefile and Media Cache
      F: SAMSUNG 850 Pro Series MZ-7KE128BW 2.5" 128GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
      for Preview and Exports.
      I'm planning on using this for exporting with Pr and Ae.
      Here're my main questions.  These are quite specific given the circumstances, so articles haven't exactly answered my them:
      1. When "Identical Drives" are needed for RAID arrays, does that include the usable disk space (such as 256GB or 128GB, etc.)?  Or does it just have to be the manufacturer/type of drive?
      2. Would any type of RAID even be applicable given the above situation?  (In your opinion)
      3. Which drives are best suited as HDDs and SSDs, in regards of FAST render times?
      4. Which of the 4 drives should be connected with RAID, if they even should be at all?
      5. Should the Source Media and Projects Drive be an HDD or SSD?  I have proper backups and all that, but SIZE MATTERS.  I have growing collections, so I need a lot of space on that drive.
      6. Between what drives does the connection need to be the fastest?  All of them?  Or some more specific than others?  I fear that if an HDD is used as a Source Media and Project drive, it may significantly lower the speed of the entire machine, considering the other drives being SSDs.  However, I don't know.
      If you need other hardware specifications, they can be found here:
        • 1. Re: Very Specific RAID Questions
          Other relevant specs:
          Chassis Cooler Master Storm Trooper Full Tower
          Power   1250W Seasonic 80PLUS Gold Power Supply
          Motherboard    Gigabyte GA-X99-UD5 2011-3, DDR4, m.2, Quad SLI, WiFi
          CPU       Intel Core i7-5960X 3.00GHz, 2133MHz DDR4, 20MB Cache, Octo Core Processor Fully Unlocked
          System Memory              64GB (8 x 8GB) , PC4-21300, 2666MHz (G.SKILL - x99)
          Video Adapter 1               NVIDIA GeForce GTX 980 4GB GDDR5
          Video Adapter 2               None
          • 2. Re: Very Specific RAID Questions
            cc_merchant Level 4
            Yes. Each member disk in an array is treated as if it has the same size as the smallest one. If you have one 128 GB disk and a number of 512 GB disks, all those 512 GB disks will be treated as 128 GB disks and the rest of the space remains unused and inaccessible.
            No. Not enough identical drives.
            Render for preview or render for export?
            None. There are not enough identical disks to warrant a raid. Even with 3 identical disks in a software raid5, the speed will be around the same as a single disk.
            On the HDD, provided you can completely turn off the "IntelliPower" feature, since it is a stupid feature that reduces the HDD to a non-suitable green disk.
            Yes.
            The system looks nice from the specs, but the disk setup is still the weak link. It would be significantly faster if you could afford four Samsung 850 Pro SSD's of 500 GB each, in addition to the 256 GB OS disk, and configure them as two raid0 arrays and use the HDD as an export drive only.
            • 3. Re: Very Specific RAID Questions
              Previews are important to me.  I highly value Realtime playback.
              Okay, so let's say I only have one 256GB Samsung 850 Pro and then four 500GB Samsung 850 Pros.
              1. Between which of those drives would you recommend a RAID0?  When you say two RAID0 arrays, are you saying between D and F and H and G, leaving the OS/Program Drive out?
              2. Does leaving the OS drive out of a RAID array create any performance degrade?
              3. With five drives (including OS drive), and no HDD, what would you recommend putting on each drive?  I used the Generic Guide for Disk Setup to determine four, but for five I don't find it to be very clear as to what should be where.
              • 4. Re: Very Specific RAID Questions
                cc_merchant Level 4
                You have to think volumes, not physical disks.
                C: Samsung 850 Pro 256 GB for OS & Programs, page file
                D: Samsung 850 Pro 500 GB (2x) raid0 for media and projects
                E: Samsung 850 Pro 500 GB (2x) raid0 for media cache and previews
                You will have 5 disks, but only 3 volumes.
                • 5. Re: Very Specific RAID Questions
                  I see.  So then would each volume have 500GB of space or 1,000GB, since it's putting two 500GB SSDs together?
