6 Replies Latest reply: Oct 6, 2014 5:48 AM by rob day RSS
    Applying full justification automatically when the last line is almost the width of the frame
    Alexander Konovalenko Community Member
      In a novel that I am setting the text will be justified. The last lines of every paragraph will be left-aligned (Left Justify).
      Some paragraphs have a long last line that almost touches the right edge of the frame. I would like those paragraphs to become full-justified, so that the last line uses the full width, like all the previous lines.
      I can go over all paragraphs in the book manually one by one (which is tedious), or I can write a script to do that (which will require learning some new APIs, testing and debugging). Is there any simple solution that I'm overlooking?
      For example, the frame width is 300 points. If the width of the last line is under 288 points, it will remain left-aligned, as usual. If its width is greater than 288 points, apply Full Justify to the whole paragraph (and possibly reflow it) and make the effective width of the last line exactly 300 points.
      Alexander
        • 1. Re: Applying full justification automatically when the last line is almost the width of the frame
          DerekC1000 Community Member
          I wouldn't bother myself, it could be slightly irritating for the reader and it might cause reflow issues if you change some words in a sentence.
          More important would be to implement Optical Margin Alignment:
          Select the paragraph(s), then from the menu select: Type > Story - select the typesize and tick the checkbox.
          • 2. Re: Applying full justification automatically when the last line is almost the width of the frame
            rob day Community Member
            I don't think there's away to do it in the GUI. If you are using OSX try this AppleScript. You would have to be careful with reflows after running this because the changed paragraphs would remain fully justified even if they shouldn't be
            --adjust this to desired percentage. Any last line that's wider than 90% of the column width gets justified
            set zone to 0.90
            tell application "Adobe InDesign CS6"
                set paras to object reference of every paragraph of every story of active document
                --check the length of each last line
                repeat with x in paras
                    --get the full column width of the paragraph
                    set i to horizontal offset of first character of line -2 of x
                    set j to horizontal offset of last character of line -2 of x
                    set colw to j - i
                    --get the last line width
                    set a to horizontal offset of first character of line -1 of x
                    set b to horizontal offset of last character of line -1 of x
                    set lastw to b - a
                    --if the last line percentage is greater than zone number justify
                    if lastw / colw is greater than zone then
                        set justification of x to fully justified
                    end if
                end repeat
            end tell
            • 3. Re: Applying full justification automatically when the last line is almost the width of the frame
              Optical Margin Alignment wouldn't affect something like the paragraph on the left, which I think is what Alexander wants to adjust:
              • 4. Re: Applying full justification automatically when the last line is almost the width of the frame
                Thanks Rob. That's exactly what I want to achieve. Unfortunately I use Windows, so I'll probably have to write some JavaScript to automate that. Looking at your script, that doesn't seem as hard as I initially thought.
                • 5. Re: Applying full justification automatically when the last line is almost the width of the frame
                  Rob - I appreciate that Optical Margin Alignment wouldn't do what Alexander wants, I was merely suggesting that if he's interested in good typographic practice for his novel he might implement this feature.
                  Derek
                  • 6. Re: Applying full justification automatically when the last line is almost the width of the frame
                    If you know some js it should be easy with the ExtendScript app, or someone in the scripting forum might translate for you. You probably should reset any fully justified paragraphs in the loop via— if justification of x is fully justified then set justification of x to left justified:
                    set zone to 0.95
                        --get all of the document's paragraphs as a list of objects
                            --reset any fully justified paragraphs
                            --catch any single line paragraphs with try
                            try
                                --get the full column width of the paragraph by measuring the 2nd to last line
                                set colw to j - i
                                set lastw to b - a
                                end if
                            end try
                        end repeat
                    end tell
