3 Replies Latest reply on Oct 5, 2014 9:54 PM by A.T. Romano
    Which Publish and Share option should I choose?
    Riverboat2001
      I'm confused about which option I should choose to output my files to.
      I'm stuck on the publish to computer option. My camera records MP4 at 25fps.
      At the moment all I'm doing is rotating videos, but I'm hoping to actually create some projects.
      So in the first place, once I've rotated my video if i just want to then save it back into my computer without increasing the file size by a massive amount, what should I pick.
      BTW, I'm in the  UK so I need to make sure it's in the pal format.
        • 1. Re: Which Publish and Share option should I choose?
          A.T. Romano Level 7
          Riverboat2001
          What version of Premiere Elements are you using and on what computer operating system is it running?
          You say that your camera records video at 25 frames per second and has a .mp4 file extension in your computer.
          But what is the frame size, 1920 x 1080 pixels or something else? Is the camera set to record interlaced or progressive video?
          Do you have any special requirements for your export in the way of format or file size?
          As an example...if your camera is recording 1080p (1920 x 1080 16:9 @ 25 progressive frames per second), you might
          want to explore the Publish+Share/Computer/AVCHD with Presets = MP4 H.264 1920 x 1080p25 for your export (that is a
          Premiere Elements 11, 12, 13 type generalization.
          Please post more details, and we will fine tune a reply for you.
          Thanks.
          ATR
          • 2. Re: Which Publish and Share option should I choose?
            Riverboat2001 Level 1
            If it helps my camera is a
            Panasonic Lumix DMC-TZ40EB
            I'm currently using Premier Elements 12 (although I Should recieve my update to 13 at some point soon.)
            Windows 7 64bit.
            The Video is 1280x720.
            At the moment I have only a few requirements
            1/ Rotate video and save it without losing any image quality.
            2/upload to Facebook.
            These are only short clips of a couple of mins, i haven't tried creating any projects yet.
            • 3. Re: Which Publish and Share option should I choose?
              A.T. Romano Level 7
              Riverboat2001
              Premiere Elements 12 Windows 7 64 bit
              Project Preset set by you (manually) or by the project (automatically)
              NTSC
              AVCHD
              AVCHD LITE 720p30
              Publish+Share
              Social Websites
              Facebook
              with Presets = Facebook HD
              OR
              Publish+Share
              Computer
              AVCHD
              with Presets = Vimeo HD
              then export to file saved to the computer hard drive and upload that file from there to the Facebook web site.
              We could do some tweaking of the export settings under the Advance Button/Video Tab of the Vimeo HD preset. But, best given
              the default settings a try before trying to alter them.
              Please review, consider, and let us know the outcome.
              Any questions or need clarification, please do not hesitate to ask.
              Thank you.
              ATR
