A problem I have encountered in PPRO CC, and now encountered in my project rendering with insane consistence. Ctrl-M, export to Adobe Encoder 2014, starts render, 3-5 minutes of problem-less rendering, then render fails with the above error in logs. Close PPRo 2014, close Encoder, reopen, reinitialize, might last longer - 10 mins., fails again. PC, i7, 16Gb RAM, 40Gbs scratch SSD disk, Quadro 2000, on the timeline a mix of Panasonic AF100 and the Lumix assortement (GH1 hacked, GH3), plus 2 GoPro 3, all AVCHD or H.264 files.
Could that be a system configuration glitch? Because I noticed that sometimes it would persistently halt render at one and the same spot, other times it will glide through it like knife through butter but halt later on a clip/inbetween clips that were of the same type. On the other hand, on the busy comb of selected clips on multiple tracks in a multi-camera gig, it is most definitely halting renders. Once I've done rendering bit by bit and have a lineup on one track with an adjustement layer on top across teh whole length of the assembled cadence of clips with a few effects on it - it finishes rendering no matter however long the workarea is, no errors then. What is up? This is driving me crazy, rendering turned into tip-toeing around this problem with the assembly of long programming out of 3-5min pieces of successful renders. Help!
