1. Re: Do I unistall PE12 to install the PS13 upgrade.
Peru Bob Oct 7, 2014 5:44 AM (in response to Riverboat2001)It is not really an upgrade. It will install version 13 as a separate and additional application. You will still be able to use either version 12 or version 13.
You may want to leave both installed in case you find that version 13 is missing a feature that version 12 had that you want to use.
2. Re: Do I unistall PE12 to install the PS13 upgrade.
nealeh Oct 7, 2014 5:46 AM (in response to Riverboat2001)No need to uninstall PSE12, just install from the new disc. You should end up with both PSE12 and PSE13 (they can coexist) installed. This is the preferred method because if there are any problems converting your catalog, you will need to fix them in v12. Once you have 13 installed and it's all working correctly you can then uninstall v12 if you want to recover the disk space.
Cheers,
Neale
If this post or another user's post resolves the original issue, please mark the posts as correct accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
