1. Re: Problem to access iOS Simulator from Flash CC
Mukesh R Shah Oct 7, 2014 7:01 AM (in response to leoluz)Can you please let us know which version of Flash CC you are using?
Have you tried with latest FlashProfessional CC 2014 update (version 14.1.0.96) released yesterday.
Also check if you are having two versions of XCode installed on your system.
Also please refer to Problem launching iOS Simulator with AIR 15.0.0.274 for more details on things you can try.
2. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 7, 2014 6:57 AM (in response to Mukesh R Shah)Hi. I already have the latest version (updated via Creative Cloud console).
3. Re: Problem to access iOS Simulator from Flash CC
Mukesh R Shah Oct 7, 2014 7:02 AM (in response to leoluz)Can you please let us know the version of Flash CC you have. Please check the "About Flash" menu.
4. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 7, 2014 7:12 AM (in response to Mukesh R Shah)14.1.0.96 from the "about flash".
I have only Xcode 6.0.1 in my system.
5. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 7, 2014 7:44 AM (in response to Mukesh R Shah) -
6. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 9, 2014 2:25 PM (in response to Mukesh R Shah)Hi, Mukesh. Any news?
7. Re: Problem to access iOS Simulator from Flash CC
Mukesh R Shah Oct 10, 2014 12:14 AM (in response to leoluz)In the latest version(6 and above) of XCode, the simulator path in the SDK has changed. Hence we see this issue.
We are looking into this issue.
Rgds,
Mukesh
8. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 10, 2014 9:19 AM (in response to Mukesh R Shah)Ok, thanks!
9. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 15, 2014 5:32 AM (in response to Mukesh R Shah)Hi. Is there any progress in solving this problem?
10. Re: Problem to access iOS Simulator from Flash CC
BenjaminParis Oct 19, 2014 2:08 AM (in response to leoluz)Any news please Adobe?
11. Re: Problem to access iOS Simulator from Flash CC
k6point7 Oct 20, 2014 8:24 AM (in response to leoluz) -
12. Re: Problem to access iOS Simulator from Flash CC
leoluz Oct 23, 2014 4:38 AM (in response to Mukesh R Shah)Hi, Mukesh. Any news? I see this question in other threads. Many await a solution. Can you give us some news?
13. Re: Problem to access iOS Simulator from Flash CC
BenjaminParis Oct 24, 2014 4:53 AM (in response to leoluz)Yes, some news would be good. Just tell us you're working on it, at least.
14. Re: Problem to access iOS Simulator from Flash CC
flashisland Oct 24, 2014 12:21 PM (in response to k6point7)We are also experiencing this same issue. Please fix soon!
15. Re: Problem to access iOS Simulator from Flash CC
Mukesh R Shah Oct 27, 2014 12:15 AM (in response to flashisland)We are working on this. We will let you know once the fix is available.
In the meantime, we are also working on a workaround for this issue.
Rgds,
Mukesh
16. Re: Problem to access iOS Simulator from Flash CC
dmonkeyjazz Oct 27, 2014 2:45 AM (in response to leoluz)I have a similar issue when installing ipas form FB, using sdk 15 (302), Xcode 6.1, iphoneSim SDK 8.1
Error occurred while installing the application:
Session did end with error (null)
17. Re: Problem to access iOS Simulator from Flash CC
flashisland Oct 27, 2014 7:20 AM (in response to leoluz)Until Adobe fixes this issue, you can use the workaround outlined at Re: iPhone 6 simulator - ipa install error - Xcode 6. You could write an ant script to speed up the process.
18. Re: Problem to access iOS Simulator from Flash CC
leoluz Nov 11, 2014 5:30 AM (in response to Mukesh R Shah)Hi Mukesh. Is there any progress in solving this problem?
