3 Replies Latest reply on Oct 7, 2014 7:17 AM by try67
    Can I remove JavaScript Editor pop-up window when running batch sequence for each PDF??
    sukhsm
      Dear All
      I need to batch process a large number of PDFs (1000s) by collapsing all
      bookmarks within them, using Adobe Acrobat 9 Pro. There is no pre-installed batch sequence for this,  so I am using the following custom Javascript action/ sequence;
      function setParentBookmarks(bm, bOpen) {
      var i;
      // If the current bookmark has any children...
      if (bm.children !== null) {
      // Open/Close the current bookmark
      bm.open = bOpen;
      // Continue with all children of this bookmark
      for (i = 0; i < bm.children.length; i += 1) {
      setParentBookmarks(bm.children[i], bOpen);
      // Close all parent bookmarks
      setParentBookmarks(bookmarkRoot, false);
      Having run this JavaScript sequence, via batch processing in 9 Pro, it successfully collapses the PDF bookmarks. However is there any way to avoid having the 'JavaScript Editor' window pop-up every time prior to processing every single PDF?? and having to manually click 'OK' on this pop-up for it to process every single PDF??
      Thanks!
