7 Replies Latest reply on Oct 10, 2014 12:34 AM by greenrookie
    AppleScript - Get links from one layer
    FredrikM Level 1
      I need to make a list of linked files from one InDesign layer only but can't figure out how.
      This is my base that works just fine but gives me a list of all linked files in my document.
      set layFilesLinksList to every link of document 1
      I have tried this
      set linksList to every link of document 1 whose active layer is "Images"
      set linksList to every link of layer "Images" of document 1
      Any other suggestions?
        • 1. Re: AppleScript - Get links from one layer
          BEGINNER_X Level 3
          Hi FredrikM,
          May the below code is useful:
          var myLinks = app.activeDocument.links;
          alert(myLinks.length);
          totalLinks = new Array();
          for(i=0; i<myLinks.length; i++)
              if(myLinks[i].parent.itemLayer.name == "Layer 1")
                  if(myLinks[i].status == LinkStatus.NORMAL)
                      alert(myLinks[i].name)
                      totalLinks.push(myLinks[i].name + "\r")
          alert("totalLinks")
          Regards
          Siraj
          • 2. Re: AppleScript - Get links from one layer
            greenrookie Level 3
            In Applescript.
            tell application "Adobe InDesign CS5.5"
                tell active document
                    if exists layer "Images" then set layerImages to layer "Images"
                    set grphicBoxs to all graphics of layerImages
                    set myLinks to {}
                    repeat with i in grphicBoxs
                        set iLink to item link of i
                        set pathLink to file path of iLink
                        set end of myLinks to pathLink
                    end repeat
                    return myLinks
                end tell
            end tell
            Greenrookie
            • 3. Re: AppleScript - Get links from one layer
              FredrikM Level 1
              Thanks for the reply Siraj, the code you pasted does not seem to be AppleScript code though and i'm not capable to translate this code into AppleScript.
              • 4. Re: AppleScript - Get links from one layer
                FredrikM Level 1
                Thanks!
                We are a bit on the way, if i run your script as stand alone i get one of many images in the layer "Images"
                But when implementing this code in my bigger script i get nothing.
                This works as before, i get every link in my document.
                on createMiniature()
                  tell application "Adobe InDesign CS5"
                  set user interaction level of script preferences to never interact
                  activate
                  set myLinks to every link of document 1
                  -- Images from one layer only workaround --
                  set myLinks to {}
                  end repeat
                  return myLinks
                  end tell
                  -- End Images from one layer only workaround --
                  repeat with thisFile in myLinks
                  set ruler origin of view preferences of document 1 to spread origin
                  set zero point of document 1 to {0, 0}
                  set zeroX to 0
                  set zeroY to ((page height of document preferences of document 1) + 5)
                  set pageHeight to ((page height of document preferences of document 1))
                  set pageWidth to ((page width of document preferences of document 1))
                  set maxHeight to 13
                  set theScale to maxHeight / pageHeight
                  set imageXPos to ((item 2 of geometric bounds of parent of parent of thisFile))
                  set imageYPos to ((item 1 of geometric bounds of parent of parent of thisFile))
                  set imageXPos2 to ((item 4 of geometric bounds of parent of parent of thisFile))
                  set imageYPos2 to ((item 3 of geometric bounds of parent of parent of thisFile))
                  set imageWidth to imageXPos2 - imageXPos
                  set imageHeight to imageYPos2 - imageYPos
                  set theName to name of thisFile
                  set filePath to ((file path of thisFile))
                  set theImgPath to quoted form of POSIX path of filePath
                  set imageStatus to ""
                  set imageStatus to do shell script ("/usr/bin/exiftool -xmp:Instructions -b " & theImgPath)
                  if imageStatus = "" then
                  set imageStatus to "Paper"
                  end if
                  set newBox to (make new rectangle of document 1 with properties {geometric bounds:{zeroY + imageYPos * theScale, zeroX + imageXPos * theScale, (zeroY + (imageYPos + imageHeight) * theScale), zeroX + (imageXPos + imageWidth) * theScale}, stroke weight:0.2, stroke color:"Black", fill color:imageStatus, active layer:StatusLayer})
                  set opacity of blending settings of fill transparency settings of newBox to 60
                  end repeat
                  set the properties of layer StatusLayer of document 1 to {visible:false}
                  end tell
                end createMiniature
                Changing the script to this gives me a blank result with no images
                  --activate
                  --set myLinks to every link of document 1
                  set myLinks to {}
                  end repeat
                  return myLinks
                  end tell
                  set zeroX to 0
                  set maxHeight to 13
                  end if
                  end repeat
                  end tell
                end createMiniature
                • 5. Re: AppleScript - Get links from one layer
                  greenrookie Level 3
                  Hi FredrikM,
                  I haven't tried your script, try replace this section with this.
                    try
                    set myLinks to {}
                    set end of myLinks to iLink
                    end repeat
                    end try
                    end tell
                  • 6. Re: AppleScript - Get links from one layer
                    FredrikM Level 1
                    Thankyou very much, just a little tweak and it works!
                      set myLinks to {}
                      end repeat
                      end tell
                    • 7. Re: AppleScript - Get links from one layer
                      greenrookie Level 3
                      You're welcome FredrikM.
                      I thought at first that you just wanted to collect the names or file paths of the links, so the initial code was to return a list of these items.
                      When you posted the code, then I understood what you were trying to do.
                      Best,
                      GreenRookie
