1. Re: Editing multiple waveform segments in Audition 3.
ryclark Oct 7, 2014 1:36 PM (in response to RickInNJ)Unfortunately there isn't a way to select multiple areas in one wave file, even in the latest versions of Audition.
However you can make a Favorite of your own to reduce level by 10dB and then assign it to a keyboard shortcut. Then it is quite quick to go through the file selecting each breath and using the shortcut key to apply the reduction.
To make a new custom Favorite go to the Favorite's menu and click on Edit Favorites. In the dialogue that opens select New and give it a name, enter a shortcut key and then go to the Functions tab. Select Amplitude and Compression/Amplify from the drop down menu. Go to Edit Settings and set the Gain to -10. Click OK then Save. Your new Favorite with it's shortcut should now appear in the Favorites menu.
2. Re: Editing multiple waveform segments in Audition 3.
RickInNJ Oct 7, 2014 3:57 PM (in response to ryclark)Thank you very much, ryclark! That is actually what I did a few days ago. Your fast response is appreciated!
Rick
